Home » Eclipse Projects » Eclipse Platform » displaying editor for a stack frame
displaying editor for a stack frame [message #98692] Wed, 23 July 2003 14:02 Go to next message
I am having trouble with a plugin for my own programming language. When
stepping into an include file, the editor for the new file does not get
displayed. Rather, the main source file editor stays current. As I continue
to step, the active line moves in my main source file. The line number that
is active in my main source file is the line number that is really executing
in my include file.
I think this might have to do with the way that I am using IStackFrame.
Conceptually, each stack frame appears to have an associated editor and
current line (although I don't see any mention of an editor in the
documentation for IStackFrame). My language plugin does not yet support
callstacks. So I only ever create one IStackFrame. I wonder is having only
this single stack frame is the reason that the editor for my include file
doesn't get displayed.
I have a source code locator, and it only gets called once at the beggining
of the debug session. Looking at the class 'LaunchView', that is part of the
Eclipse core, it seems that the editor gets cached and so my source locator
is only ever called once. How can I get my source code locator to be called
after every step action, or breakpoint?
Here is the caching code from LaunchView
(org.eclipse.debug.internal.ui.views.launch)
protected void openEditorForStackFrame(IStackFrame stackFrame) {
if (fShowingEditor) {
return;
try {
fShowingEditor = true;
if (!stackFrame.isSuspended()) {
return;
//!!! no editor lookup if we already have one
if (stackFrame.equals(getStackFrame())) {
if (getEditorInput() == null || getEditorId() == null) {
lookupEditorInput(stackFrame);
} else {
setStackFrame(stackFrame);
return;
note:
protected IEditorInput getEditorInput() {
return fEditorInput;
protected IEditorInput getEditorId() {
return fEditorId;
Patrick Baker
Stilo Corporation
pbaker@ca.stilo.com
"Hail, twin companionship, children of Mars."
This message, including any attachments, is for the sole use of the
intended recipient(s) and may contain confidential and privileged
information. Any unauthorized review, use, disclosure, copying, or
distribution is strictly prohibited. If you are not the intended
recipient(s) please contact the sender by reply email and destroy
all copies of the original message and any attachments.
Re: displaying editor for a stack frame [message #98724 is a reply to message #98692] Wed, 23 July 2003 15:42 Go to previous message
When you move to the new source code locator, you will need to fire a debug
event notifying that a change has occurred for the stack frame.
This will remove the cached stack frame in the launch view and force another
source lookup.
See LaunchViewEventHandler.doHandleDebugEvents and
LaunchView.setStackFrame(IStackFrame)
HTH
Darins
"Patrick Baker" <pbaker@ca.stilo.com> wrote in message
news:bfmik9$lk7$1@eclipse.org...
continue
that
executing
> in my include file.
beggining
the
locator
called
> return;
> try {
> return;
> } else {
> return;
> note:
> return fEditorId;
> Thanks
> Patrick Baker
> Stilo Corporation
> pbaker@ca.stilo.com
Previous Topic:Re: mark editor as dirty
Next Topic:Re: CDT in CVS repository?
Current Time: Sun Jun 22 01:53:57 EDT 2025
Powered by FUDForum. Page generated in 0.02984 seconds
