Home » Language IDEs » C / C++ IDE (CDT) » M8 prefs/workbench/startup error
M8 prefs/workbench/startup error [message #98569] Sat, 03 April 2004 12:33 Go to next message
Originally posted by: kk.gravitas.org
Sorry about the previous, posted by mistake.
I have downloaded Eclipse / CDT M8, and I am having this strange behaviour.
After I have installed cDT/ Standard Make and Managed Make M8 using the
update manager, after restarting eclipse, I opened the
preferences/workbench/startup page I have seen two entries, one is the
automatic updates scheduler, the other is the C/C++ Standard make Build
UI. However, after I have closed eclipse and restarted once I open
preferences/workbench/startup I get an error dialog saying
"The currently displayed page contains invalid values."
Then when I open the startup page, I see that, automatic updates scheduler
check box is there, but the second one C/C++ Standard make Build UI,
appears only as a check box, the text associated with the check box does
not exist.
I have installed eclipse/cdt a couple of times from zero to be sure that
error is repeatable, and yes it is. I get the same behaviour every time.
I checked with my M7, and 2.1.2 installations, and they work fine. Does
anybody have a similar problem?
Koray
Re: M8 prefs/workbench/startup error [message #98645 is a reply to message #98569] Mon, 05 April 2004 08:15 Go to previous message
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=57409
In the process on being fixed.
Koray Kavukcuoglu wrote:
> not exist.
> Koray
Previous Topic:auto-complete user defined class members ?
Next Topic:whats wrong
Current Time: Sun Aug 31 10:48:09 EDT 2025
Powered by FUDForum. Page generated in 0.23943 seconds
