Home » Language IDEs » ServerTools (WTP) » M4: Filter subversion folders (.svn/) to be deployed under .deployables
M4: Filter subversion folders (.svn/) to be deployed under .deployables [message #98528] Wed, 04 May 2005 08:52 Go to next message
Originally posted by: ceeneel.gmail.com
I would like to set filter so Ecilpse will not copy .svn folders to
..deployables. Is there any setting for it. (.wtpmodules?)
I am able to set filter for JavaSource under Java-Compiler-Building-Output
Folder-Filtered Resources.
Thanks, Yogesh
Re: M4: Filter subversion folders (.svn/) to be deployed under .deployables [message #99935 is a reply to message #98528] Fri, 06 May 2005 03:07 Go to previous messageGo to next message
Which Subversion plugin are you using? It should be marking the
..svn folders as Team private so they're ignored by the deployment
builder (and pretty much everything else).
- Nitin
Re: M4: Filter subversion folders (.svn/) to be deployed under .deployables [message #102537 is a reply to message #99935] Wed, 11 May 2005 13:26 Go to previous messageGo to next message
I am having the same problem and I am using a combination of Subclipse and
TMatesoft JavaSVN.
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:d5f5gf$4le$2@news.eclipse.org...
> - Nitin
Re: M4: Filter subversion folders (.svn/) to be deployed under .deployables [message #112037 is a reply to message #99935] Thu, 16 June 2005 14:28 Go to previous message
Originally posted by: thisisnot.mymail.com
If I'm not using any svn plugin for eclipse but an external tool
(TortoiseSvn), is there a way to hide the .svn directories ?
>> Java-Compiler-Building-Output Folder-Filtered Resources.
> Which Subversion plugin are you using? It should be marking the .svn
> folders as Team private so they're ignored by the deployment builder (and
> - Nitin
Previous Topic:xdoclet and MDBs
Next Topic:Structured Source Editor (SSE) docs?
Current Time: Sun Jul 13 09:14:28 EDT 2025
Powered by FUDForum. Page generated in 0.05236 seconds
