Home » Newcomers » Newcomers » Solaris 8 (SPARC/GTK 2) ... getting gtk2
Solaris 8 (SPARC/GTK 2) ... getting gtk2 [message #98524] Tue, 30 August 2005 11:19 Go to next message
Originally posted by: carley.lsil.com
I would like to use Solaris 8 (SPARC/GTK 2) instead of the motify version
on solaris ... looks nicer ... seems to behavior better.
However, i'm having trouble finding GTK2 and supporting libraries that run
successfully.
How was this version of eclispe built .. against what versions of Gtk (and
libraries)? Was this built against some standard pkg from Sun ... or from
sunfreeware.com .. or ...
In my latest attempt, i have collected sufficient libraries from
sunfreeware.com ... enough to satisfy ldd. I get the following error
(rweclipse is my RCP).
Any help would be appreciated.
thanks.
--carley
GLib: Cannot convert message: Conversion from character set 'UTF-8' to
'646' is not supported
Pango:/lsi/home/carley/sunfreeware/sol8-lib/pango.modules:6: A [SECTION]
declaration must occur first
(rweclipse:20407): Pango-WARNING **: No builtin or dynamically loaded
modules
were found. Pango will not work correctly. This probably means
there was an error in the creation of:
'/usr/local/etc/pango/pango.modules'
You may be able to recreate this file by running pango-querymodules.
(rweclipse:20407): Pango-WARNING **: Couldn't load font "Sans 10" falling
back to "Sans 10"
back to "Sans 10"
(rweclipse:20407): Pango-WARNING **: All font failbacks failed!!!!
Re: Solaris 8 (SPARC/GTK 2) ... getting gtk2 [message #98570 is a reply to message #98524] Tue, 30 August 2005 12:15 Go to previous message
Previous post should have said "instead of motif".
Found part of the problem .... bad pangorc file. So now i have:
(rweclipse:21162): Pango-WARNING **: Couldn't load font "Sans 10" falling
back to "Sans 10"
back to "Sans 10"
(rweclipse:21162): Pango-WARNING **: All font failbacks failed!!!!
Previous Topic:Class Not Found: javax.crypto.Cipher in Eclipse.
Next Topic:Migrating from Visual Age for Java - VAJ
Current Time: Mon Jul 21 22:09:37 EDT 2025
Powered by FUDForum. Page generated in 0.12813 seconds
