Home » Eclipse Projects » Remote Application Platform (RAP) » How to fill and center using GridData
How to fill and center using GridData [message #98418] Tue, 15 July 2008 12:24 Go to next message
I would like to center a composite and to fill it (i.e. to grab excess
space).
From my point of view, it should be defined like that :
new GridData(int,SWT.CENTER,boolean,true)
but the grab seems to do not work...
Apparently, the grab or fill (what's the difference ?) only works with
new GridData(int,SWT.FILL,boolean,true)
but the SWT.FILL aligns my composite in the top
new GridData(int,SWT.FILL|SWT.CENTER,boolean,true) doesn't work better...
Any ideas ?
Thanks !
Emmanuel
Re: How to fill and center using GridData [message #98496 is a reply to message #98418] Tue, 15 July 2008 13:05 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Emmanuel,
not sure what you mean with "center a composite and to fill it".
Rüdiger
Emmanuel wrote:
> space).
> Any ideas ?
> Thanks !
> Emmanuel
Re: How to fill and center using GridData [message #98582 is a reply to message #98496] Wed, 16 July 2008 03:41 Go to previous messageGo to next message
Ok I was a bit confused...
Consider a gridlayout containing two cells in the same row. The first one
contains the highest composite (determining the height of the row). The
second cell contains a Label with a background color.
I would like to fill the cell so that the background color of my label
will cover all the cell BUT I also would like to have the text centered
vertically in the cell...
Maybe I could achieve that giving a "VERTICAL_CENTER" style to Label (No
idea how to do that !)
I hope that it's clearer...
Emmanuel
Re: How to fill and center using GridData [message #98598 is a reply to message #98582] Wed, 16 July 2008 03:47 Go to previous messageGo to next message
You may put a composite which in turn contains your label. Then you can
set the background color of that composite.
Re: How to fill and center using GridData [message #98613 is a reply to message #98598] Wed, 16 July 2008 03:54 Go to previous messageGo to next message
I've forgotten to say that I would like to minimize the use of
intermediate composite. The creation of composites is still very slow in
RAP and some of my gridlayouts contain hundreds of cells...
The idea should be to achieve that with only one composite...
Re: How to fill and center using GridData [message #99361 is a reply to message #98613] Tue, 22 July 2008 08:40 Go to previous messageGo to next message
Any idea how I can center vertically the text in a Label ?
Re: How to fill and center using GridData [message #99391 is a reply to message #99361] Tue, 22 July 2008 09:59 Go to previous message
Originally posted by: rsternberg.innoopract.com
Hi Emmanuel,
as far as I know, it is not possible to center the contents of a Label
vertically. Reducing the number of composites is surely a good idea. But
in this case, this seems to be the only way.
If you're looking for SWT tricks, you might get more answers on the SWT
newsgroup.
Best regards, Ralf
Previous Topic:1.1.1 I-Build
Next Topic:DateTime/Calendar
Current Time: Fri Nov 21 04:30:16 EST 2025
Powered by FUDForum. Page generated in 0.05127 seconds
