| build the BIRT project [message #8939] |
Fri, 18 February 2005 06:53  |
I have checked out the BIRT projects (20 eclipse projects).
And now I try to build them.
1.) I generate the build.xml for the org.eclipse.birt-feature project
2.) I call the ant
I have a lot of error in my build like:
[javac] ----------
[javac] 1. ERROR in
/home/andherz/workspace/org.eclipse.birt.report.data.oda.jdb c.ui/src/org/eclipse/birt/report/data/oda/jdbc/ui/editors/Jd bcSQLContentAssistProcessor.java
(at line 22)
[javac] import org.eclipse.birt.report.designer.ui.editors.sql.ISQLSyntax;
[javac] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[javac] The import org.eclipse.birt.report.designer.ui.editors cannot be resolved
[javac] ----------
[javac] 2. ERROR in
(at line 51)
[javac] ISQLSyntax
[javac] ^^^^^^^^^^
[javac] ISQLSyntax cannot be resolved to a type
[javac] ----------
[javac] ----------
[javac] 3. ERROR in
/home/andherz/workspace/org.eclipse.birt.report.data.oda.jdb c.ui/src/org/eclipse/birt/report/data/oda/jdbc/ui/editors/Jd bcSQLSourceViewerConfiguration.java
(at line 12)
[javac] import
org.eclipse.birt.report.designer.ui.editors.sql.SQLSourceVie werConfiguration;
[javac] ----------
[javac] 4. ERROR in
(at line 26)
[javac] SQLSourceViewerConfiguration
[javac] SQLSourceViewerConfiguration cannot be resolved to a type
Is there any HowTo to extract/build/first use of the BIRT project??????????
Greetings
Andreas
FUDForum. Page generated in 0.05036 seconds
