Home » Language IDEs » Java Development Tools (JDT) » can't extend my class to CompilationUnitEditor
can't extend my class to CompilationUnitEditor [message #98199] Tue, 23 September 2003 12:30 Go to next message
Hi all,
I have read in the article at Eclipse that I can 't extend my editor to
CompilationUnitEditor as it is an internal API.
Now my question is that I need to have some of the javaeditor
functionality in my javaeditor(the one i created).How can I get this
functionality.
Any idea/pointer or example code will really be appreciated.
Thanks in advance
Syed
Re: can't extend my class to CompilationUnitEditor [message #98490 is a reply to message #98199] Wed, 24 September 2003 03:17 Go to previous messageGo to next message
Originally posted by: t_tcholakov.prosyst.bg
Yes it is internal. And still you CAN extend it.
however when testing you should include the appropriate plugins if you want
to run your editor without errors.
I've done it and it works ok for naow. I've tested it on eclipse 2.0, 21 and
3.0 and there are no chnghes in this functionality.
just override the class and set the plugin in which it stays as required.
that's all :))
"Syed" <sma_r@hotmail.com> wrote in message news:bkpsfk$hhh$1@eclipse.org...
> Hi all,
> functionality.
> Thanks in advance
> Syed
Re: can't extend my class to CompilationUnitEditor [message #98594 is a reply to message #98490] Wed, 24 September 2003 10:09 Go to previous messageGo to next message
Originally posted by: tom.eicher.gmx.ch.nodomain
You are writing your own editor? Why don't you copy
CompilationUnitEditor and everything you need from the internal
packages? This way you won't have to worry about it changing.
"Internal" just means there is no support, and that interfaces and
behaviour can change any time - you may still use the source.
-tom
> that's all :))
>>Hi all,
>>functionality.
>>Thanks in advance
>>Syed
Re: can't extend my class to CompilationUnitEditor [message #98952 is a reply to message #98490] Thu, 25 September 2003 10:02 Go to previous message
How can you extend it,besides copying all all files of the plugin.
thanks
Syed
> that's all :))
> > Hi all,
> > functionality.
> > Thanks in advance
> > Syed
Previous Topic:finding the JDK version of an IVMInstall
Next Topic:Support Clearcase
Current Time: Sun Nov 09 11:24:47 EST 2025
Powered by FUDForum. Page generated in 0.03484 seconds
