Home » Archived » BIRT » PDF Columns in M3
PDF Columns in M3 [message #98025] Fri, 09 December 2005 13:21 Go to next message
Originally posted by: kj.kwjames.com
Has anyone else had issues with column widths in the PDF output of M3? PDF
generation seems very good overall, but an old bug where the PDF engine
ignores column widths in tables seems to still be there.
I searched bugzilla, and there seems to be a couple bugs in there for
this, 112319 being the closest description. Does anyone know a
hack/workaround to force column widths in PDF? Thanks.
Re: PDF Columns in M3 [message #98189 is a reply to message #98025] Sat, 10 December 2005 04:32 Go to previous messageGo to next message
Originally posted by: sangria.gmx.net
I reported the following bug last week: https://bugs.eclipse.org/bugs/show_bug.cgi?id=119397
Does that describe the problem you've got?
michael
> PDF generation seems very good overall, but an old bug where the PDF
> engine ignores column widths in tables seems to still be there.
Re: PDF Columns in M3 [message #98204 is a reply to message #98189] Sat, 10 December 2005 08:56 Go to previous messageGo to next message
Exactly, that's the one. I noticed this comment:
------- Comment #2 From Gang Liu 2005-12-08 22:32 [reply] -------
Fixed in new BIRT PDF emitter
I'll try your example in the newest nightly build, and see if it works.
Re: PDF Columns in M3 [message #98219 is a reply to message #98204] Sat, 10 December 2005 12:45 Go to previous messageGo to next message
I can't find a build newer than M3 that is stable enough to preview a
report, so I can't test this. But I suspect it isn't fixed. How does this
work anyway, can random people reopen bugs, or is that best left to the
actuate team? Thanks.
Re: PDF Columns in M3 [message #98777 is a reply to message #98025] Tue, 13 December 2005 08:12 Go to previous messageGo to next message
Originally posted by: mlorenz.nc.rr.com
I experience the same problem in 2.0M3.
This is a major problem for me, since my required output format is PDF.
Anyone know if someone is fixing this for rel2.0?
Re: PDF Columns in M3 [message #98807 is a reply to message #98777] Tue, 13 December 2005 10:13 Go to previous message
I searched the dev newsgroup, and I think this will be fixed in 2.0 final.
It looks like the PDF emitter was changed post-M3, which fixes a whole
bunch of PDF bugs. I'll confirm this when the next stable nightly build is
produced.
Previous Topic:Dynamic / Editable Reports
Next Topic:M3: installation problems (IPlatformContext,
Current Time: Wed Nov 05 00:44:26 EST 2025
Powered by FUDForum. Page generated in 0.06450 seconds
