Home » Modeling » GMF (Graphical Modeling Framework) » Behaviour of shouldBeDeleted in generated CanonicalEditPolicies
Behaviour of shouldBeDeleted in generated CanonicalEditPolicies [message #97944] Mon, 29 January 2007 07:23 Go to next message
Hi GMF-users and developers,
currently the code body of the shouldBeDeleted()-method in the generated
CanoncialEditPolicies for Compartments looks like this:
return view.isSetElement() && view.getElement() != null
&& view.getElement().eIsProxy();
Why isn't it checking if view.getElement() is still available in the
List of semantic children, i.e.
|| getSemanticChildrenList().contains(view.getElement());
Can I activate this behaviour during the generation process or must I
implement it manually?
Greetings,
Alexander
Re: Behaviour of shouldBeDeleted in generated CanonicalEditPolicies [message #98047 is a reply to message #97944] Mon, 29 January 2007 08:38 Go to previous messageGo to next message
Hello Alexander,
Correct implementation of this method was discussed here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=157148
Alex Shatalin
Re: Behaviour of shouldBeDeleted in generated CanonicalEditPolicies [message #98137 is a reply to message #97944] Mon, 29 January 2007 10:17 Go to previous messageGo to next message
Originally posted by: vcciubot.uwaterloo.ca
When the canonical policy reacts to changes from the semantic model, it
sweeps through the children views of the current node to see which ones
should be deleted.
The check is correct because it is performed on a view whose element is
not in getSemanticChildrenList() anymore.
vlad
> Greetings,
> Alexander
Re: Behaviour of shouldBeDeleted in generated CanonicalEditPolicies [message #101398 is a reply to message #98137] Tue, 06 February 2007 07:03 Go to previous message
> should be deleted.
I have a method in my EMF-Model which moves a semantic node from one
container to another. If I use my subvlass of AbstractEMFCommand to call
this method I end up with to notational nodes: one in the target
container as intended and one in the source container. It didn't get
deleted. If I check the EMF-Model everything is changed as intended, and
there are two notational nodes referencing on the same semantical node.
Greetings,
Alexander
Previous Topic:Setting data to the model Element
Next Topic:Resizing Parent node as Label /Child is resized/added
Current Time: Fri Jul 25 22:07:48 EDT 2025
Powered by FUDForum. Page generated in 0.28283 seconds
