Home » Language IDEs » ServerTools (WTP) » Define custom mapping for package to namespace
Define custom mapping for package to namespace [message #97920] Tue, 03 May 2005 10:57 Go to next message
When i right-click a java file select web service -> create web service and
go through wizard. On page 4 of the wizard 'Web service java bean
dentity' - where you choose the methods to expose. There is a check-box at
the bottom 'Define custom mapping for package to namespace'
Can someone explain this to me please
Many thanks
Re: Define custom mapping for package to namespace [message #100449 is a reply to message #97920] Fri, 06 May 2005 17:10 Go to previous message
Packages in Java are mapped to namespaces in WSDL and vice-versa. For example,
if your Java bean is in a package called webservice.addressbook the generated
WSDL will have a target namespace of http://addressbook.webservice by default.
If you check the "Define custom mappings ..." checkbox, the following page of
the wizard will let you customize this mapping.
> Many thanks
Previous Topic:JBoss 3.2.6 problem
Next Topic:JSP and Ant
Current Time: Thu Jul 17 10:11:25 EDT 2025
Powered by FUDForum. Page generated in 1.28823 seconds
