Home » Eclipse Projects » Equinox » Equinox + WebService
Equinox + WebService [message #97871] Thu, 20 September 2007 11:22 Go to next message
Originally posted by: martin.roth.access.unizh.ch
has anybody managed to plug a webservice stack into equinox? i'm trying
to expose existing eclipse-plugins as webservices.
i would like to use a newer technology than axis1 (an example described
earlier in this list), but i wasn't able to bring axis2 to work...
thanks a lot in advance for tips, code snippets, links... !
cheers
Re: Equinox + WebService [message #98121 is a reply to message #97871] Mon, 24 September 2007 06:29 Go to previous message
Originally posted by: normad2.web.de
I can't help you because I don't know either. :) But I will give you some
links which may help you:
Expose plug-ins as Web services with Eclipse (Axis1.x)
http://www.ibm.com/developerworks/edu/ws-dw-ws-eclipseplugin .html
Eclipse-Plugin für XFire (german)
http://entwickler.de/zonen/portale/psecom,id,101,online,990, p,0.html
Nyota
http://eclipse.compeople.eu/wiki/index.php/Nyota:Main
It uses Hessian as binary based Web Service.
Open Healthcare Framework (OHF) Project - OHF Bridge
http://www.eclipse.org/ohf/components/bridge/
The OHF-Project uses Axis1.x under the hood so far I know. Perhaps you can
get some information from code.
T.Gau
Previous Topic:How do I run Equinox as a daemon?
Next Topic:Which is the relation from plugins and bundles ?
Current Time: Tue Jul 22 01:54:44 EDT 2025
Powered by FUDForum. Page generated in 1.68609 seconds
