Home » Language IDEs » Java Development Tools (JDT) » Debug: F6 is fast, F8 is slow
Debug: F6 is fast, F8 is slow [message #97831] Mon, 22 September 2003 06:29 Go to next message
Originally posted by: jcohrs.gmx.de
I have a debug problem which is as follows:
In my code I have a method that contains calls to an external java
library/jar-file. I have set a breakpoint on a call to that method.
When I step over my breakpoint using F6, I am back in reasonable time,
say one second or so. I then continue with F8 and everything is fine.
Now, if I use F8 to step over the same breakpoint it costs me about 40
seconds or even more!
I am using Java 1.3.0 and Eclipse 2.1.1 on W2k Server.
Is this a known behaviour? Is there a way to work around this problem?
Joco
Re: Debug: F6 is fast, F8 is slow [message #98184 is a reply to message #97831] Tue, 23 September 2003 11:46 Go to previous message
joco wrote:
> Best regards,
> Joco
I switched to java 1.4.2 and now the problem is gone ...
Previous Topic:I would like to progammatially open .class file
Next Topic:Eclispe Plugins
Current Time: Mon Nov 03 21:04:46 EST 2025
Powered by FUDForum. Page generated in 0.05166 seconds
