Home » Archived » M2M (model-to-model transformation) » [Declarative QVT] Transformation problem , beginer
[Declarative QVT] Transformation problem , beginer [message #97818] Mon, 19 January 2009 19:09 Go to next message
Hello
I am totally new in QVT Relational. I have the following problem, I am
trying to transform a model based on requirements from a model based on
features , but in execution time my program totally crash. This is a
fragment of my code, i think thereÂŽs something wrong with this code. Any
suggestions ?
Thanks !
top relation FeaturesToRequirements {
n1:String;
n2:String;
n3:String;
checkonly domain feature f1: Features::Feature {
description = n1,
rationale = n2,
catalogue = c1 : Features::Catalogue {},
agreement = n3
/*level = l1 : Features::MandatoryLevel {},
composited_by = compo1 : Features::CompositionRule {},
refine_and = ref1 : Features::Feature {},
trace_to = tra1 : Features::TextualRequirement {},
type = ty1 : Features::FeatureType {}*/
enforce domain req t1: Requirements::TextualRequirement {
description = n1,
rationale = n2,
catalogue = c2 : Requirements::Catalogue {},
document = doc : Requirements::Document {}
when {
CatalogueToCatalogue(c1,c2);
CatalogueToDocument(c1,doc);
where {
FeatureToSections(f1,doc,t1) or FeatureToRoot(f1,doc,t1);
relation FeatureToSections {
n1:String;
description = n1,
refine_and = ref : Features::Feature {}
checkonly domain req doc : Requirements::Document {};
enforce domain req t1: Requirements::TextualRequirement{
section = s1 : Requirements::Section {
heading = n1,
document = doc
relation FeatureToRoot {
n1:String;
description = n1
document = doc,
section = doc.sections->first()
Re: [Declarative QVT] Transformation problem , beginer [message #97895 is a reply to message #97818] Tue, 20 January 2009 12:10 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
--------------080307080308070206010709
First please note that the current compiler is under strong rewriting to
bypass its current limitations. The version available on download is
unstable. A fix will be available by the next eclipse release. I'll
advertise it on the newsgroup.
Now concerning the the style of the transformation, it is difficult to
answer without the metamodels and the wanted semantics. However, here is
my notes.
The rules "FeatureToSections" and "FeatureToRoot" are using several
times the same domain "req". As at runtime you have to choose a
direction, each rule have to refer to a domain at most once.
In the rule "FeaturesToRequirements", the "where" section have a "or"
function. An OCL strict evaluation will then evaluate both the source
(FeatureToSections) and the argument (FeatureToRoot) whereas this latter
has a condition expression for the "feature" domain relaxed compared to
the one for the same domain in "FeatureToSections".
In this case, I guess it is better to use condition expression that
creates a partition of your elements. Maybe like the following:
n1:String;
description = n1
} {f1.refine_and.oclIsUndefined() };
Quentin
jorge a
Re: [Declarative QVT] Transformation problem , beginer [message #98030 is a reply to message #97895] Wed, 21 January 2009 20:52 Go to previous message
Hello
Yes finally its working for the moment, thank for that suggestions.
I made note of that.
Jorge
Previous Topic:[ATL]Specification attribute not set in uml:Activity
Next Topic:Get The elements from xmi
Current Time: Fri Jul 18 04:08:02 EDT 2025
Powered by FUDForum. Page generated in 0.09326 seconds
