AGR - The references for two different Edit Boxes set to the same value [message #97697] |
Fri, 04 May 2007 04:04  |
Originally posted by: sluhay.magenta-technology.ru
Hi All,
Could you please give me any idea how to solve the following problem?
I record a test case. The references for two different Edit Boxes set to
the same value during the test case recording (see fragments '6' and '7'
in generated XML script below). As a result, playback of the test case is
failed because only one required filed is filled.
And the next quick question:
Is it better to include object id in test macro or register object ids
with object mine?
Basically I use the second option.
<!--1-->
<macro version="1.0">
<!--2-->
<shell descriptive="Platform SDK - TestSuite - Eclipse SDK"
id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<!--3-->
<command descriptive="Platform Application Project" type="select"
resolverId="org.eclipse.tptp.test.auto.gui.nontrivial" contextId="menus"
widgetId="{{File-New&#x9;Alt+Shift+N-Platform Application
Project}}-{{1.0}}"/>
<!--4-->
<shell descriptive="Create Platform Application Project"
id="org.eclipse.jface.wizard.WizardDialog" return-code="0">
<!--5-->
<command type="modify" contextId="wizard-page/Create Platform
Application Project" widgetId="org.eclipse.swt.widgets.Text#1">
<![CDATA[TMP]]>
</command>
<!--6-->
contextId="wizard-page/Create Platform Application Project" widgetId="7.0">
<![CDATA[TempApplication]]>
</command>
<!--7-->
<![CDATA[temp.com]]>
</command>
<!--8-->
<command descriptive="Finish" type="select"
resolverId="org.eclipse.tptp.test.auto.gui.adaptive" contextId="wizard"
widgetId="{{16}}-{{1.0}}"/>
<!--9-->
</shell>
<!--10-->
</shell>
<!--11-->
</macro>
Re: AGR - The references for two different Edit Boxes set to the same value [message #98370 is a reply to message #98266] |
Wed, 09 May 2007 15:39  |
Hi Olesya,
This sounds like it is related to the following open defect:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=171083
Please feel free to add yourself to the CC list to follow its progress.
Sincerely,
Liz Dancy
"Sluhay Olesya" <sluhay@magenta-technology.ru> wrote in message
news:f1q1sc$u4l$1@build.eclipse.org...
> Hi Liz,
> The test case main idea consists in filling of custom form which contains
> standard widgets like text, button and label. For example,
> Text1 field
> Text2 field
> Text3 field
> Label field that filled dynamically depending on Text3 value
> Button1
> Button2
> Note: Value is set to Text3 field by default at form opening. Label has a
> value as well because of dependency.
> I fill this from the top to the bottom at test case recording. As a
> result, the same references for two different fields (Text1 and Text2) are
> appeared in macro:
> <command type="modify" referenceId="3">
> <![CDATA[NEW]]>
> </command>
> <command type="modify" referenceId="4">
> <![CDATA[MyNew]]>
> </command>
> <![CDATA[mynew.com]]>
> </command>
> But if I record a test cases started from cleaning the Text3 field, next I
> go to the top of form and fill it step by step then I see different
> references for two different fields as expected.
> <![CDATA[NEW]]>
> </command>
> <command type="modify" referenceId="7">
> <![CDATA[MyNew]]>
> </command>
> <command type="modify" referenceId="8">
> </command>
> Thanks a lot,
> Olesya
> "Liz Dancy" <lizdancy@ca.ibm.com>
FUDForum. Page generated in 0.02713 seconds
