Logging Agent Termination [message #97682] |
Fri, 04 May 2007 00:41  |
Originally posted by: zclipse.gmail.com
Hello, while studying the org.eclipse.hyades.perfmon code, I have a
question:
The perfmon agent is currently being 'terminated' when the user presses the
'terminate' button.
This is currently being handled in the 'ProcessControlProvider'
implementation.
---> ??How can I intercept this termination and handle it on my own ???
(for e.g. I dont want to 'terminate' the Perfmon.exe's process).
I noticed that the extension point
""org.eclipse.hyades.trace.ui.controllableEntity"" associates the
ProcessControlProvider to all agents that are type "logging"
<control associatedAgentId = "org.eclipse.tptp.trace.ui.logging">
<entity type = "process"
class =
" org.eclipse.tptp.trace.ui.provisional.control.provider.Proce ssControlProvider "/>
Re: Logging Agent Termination [message #98426 is a reply to message #97682] |
Thu, 10 May 2007 21:01  |
There is no control provider associated with a perfmon agent. Any agent
without a control provider is automatically assigned to the PI's agent
control provider (which was required because of backward compatibility).
Although you can write your own control provider and have it associated with
a statistical agent, it's not really a good idea to do that. It's only
kosher to write control providers for agents that your code owns. Since you
don't really own the TPTP pefmon agent, then your code shouldn't dictate how
it's associated actions should behave (btw, nothing is stopping you from
breaking the rules here).
To find out more about control providers, see
http://www.eclipse.org/tptp/platform/documents/tutorials/dat acollection/launch-extensions/extending-launch-configuration .html#2.3
Ali Mehregani
"Emura" <zclipse@gmail.com> wrote in message
news:f1edh2$pnm$1@build.eclipse.org...
> question:
> the 'terminate' button.
> implementation.
> class =
> Thanks
FUDForum. Page generated in 0.03252 seconds
