Home » Language IDEs » Java Development Tools (JDT) » 3.0 code formatter question
3.0 code formatter question [message #97654] Sat, 20 September 2003 16:47 Go to next message
Originally posted by: rmaker.cs.brandeis.edu
I am experimenting with 3.0M3, and I can't figure out one code formatting
customization.
| = cursor position
When I have
if(someBoolean)|
and I hit enter, the cursor position changes to:
if(someBoolean)
And I would like it to change to:
if(someBoolean)
What setting do I need to change to get this to happen?
Thanks in advance,
Reid
Re: 3.0 code formatter question [message #97741 is a reply to message #97654] Sun, 21 September 2003 17:47 Go to previous messageGo to next message
Originally posted by: tom.eicher.name
You can't change that at the moment. Code formatting is being reworked
in several areas for 3.0, and the current preferences have very limited
coverage. If you hit Insert, you can leave the smart mode, however, no
autoindentation what so ever will happen then - probably not what you want.
Just out of curiosity: can you explain why you want the conditional
statement on the same indentation level? Note that if you enter an
opening brace at in the situation you describe, it will automatically
move back to the correct position.
if (someBoolean)
someMethod();
but:
if (someBoolean)
someMethod();
-tom
> customization.
> | = cursor position
> When I have
> if(someBoolean)|
> if(someBoolean)
> if(someBoolean)
> Thanks in advance,
> Reid
Re: 3.0 code formatter question [message #99402 is a reply to message #97741] Sat, 27 September 2003 12:56 Go to previous messageGo to next message
Tom,
When I type:
someMethod() and hit enter, it will put me
here. If I hit {, it will make it look like:
someMethod()
Which is not what I want...
Reid
> if (someBoolean)
> someMethod();
> but:
> if (someBoolean)
> someMethod();
> -tom
> > customization.
> > | = cursor position
> > When I have
> > if(someBoolean)|
> > if(someBoolean)
> > if(someBoolean)
> > Thanks in advance,
> > Reid
Re: 3.0 code formatter question [message #99417 is a reply to message #99402] Sat, 27 September 2003 13:43 Go to previous message
this is fixed in a newer build.
johan
Reid Maker wrote:
> Tom,
> When I type:
> someMethod()
> Reid
>>if (someBoolean)
>> someMethod();
>>but:
>>if (someBoolean)
>> someMethod();
>>-tom
>>>customization.
>>>| = cursor position
>>>When I have
>>>if(someBoolean)|
>>>if(someBoolean)
>>>if(someBoolean)
>>>Thanks in advance,
>>>Reid
Previous Topic:ant in external vm
Next Topic:JVM terminated exit code 1
Current Time: Sun Aug 31 07:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.03078 seconds
