Home » Archived » M2M (model-to-model transformation) » XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD
XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD [message #97651] Wed, 14 January 2009 11:28 Go to next message
Originally posted by: postit.post.it
I am trying to turn two XSDs into ecore metamodels, and I succeeded in doing
this. Using EMF I can now generate an editor that creates XML instances for
the XSDs.
However, when I try to execute an ATL transformation on one XML instance, to
obtain an instance of the other model, I get the error below (My.gse is an
XML file conforming to the ecore model generated from the XSD and to the XSD
itself of course).
I defined the two ecore models created from the XSDs as metamodels, and I
consider their XML instances as the models when I run the transformation.
Do I miss a step here? Do I have to define the models as ecore files too?
How do I make sure they comply with the metamodels based on XSD?
Can somebody put me on the right track? (Yes, I can do this with XSLT,
without the ecore deviation, but I want to use the ecore stuff to build
Eclipse editors for the metamodels...)
Thank you for any help!
Bart Decuypere
eclipse.buildId=M20080911-1700
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_BE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
Error
Wed Jan 14 17:01:01 CET 2009
An internal error occurred during: "Launching bla".
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'books' not found.
(platform:/resource/test/src/book/My.gse, 2, 40)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
at org.eclipse.m2m.atl.engine.emfvm.lib.Model.<init>(Model.java:67)
org.eclipse.m2m.atl.engine.emfvm.AtlEMFSpecificVM.actualLaun ch(AtlEMFSpecificVM.java:153)
org.eclipse.m2m.atl.engine.emfvm.AtlEMFSpecificVM.launch(Atl EMFSpecificVM.java:120)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
Caused by: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'books'
not found. (platform:/resource/test/src/book/My.gse, 2, 40)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2229)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.validateCreateObje ctFromFactory(XMLHandler.java:2220)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1318)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1454)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1019)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:1001)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.scanStartElement(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl$NSContentDriver.scanRootElementHook(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScanner Impl.next(Unknown
Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1445)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1241)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
.... 10 more
Re: XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD [message #98074 is a reply to message #97651] Thu, 22 January 2009 03:27 Go to previous messageGo to next message
Hello Bart,
> this. ...
How have you done this. Is there a tutorial out there to do so?
Taking the XML Schema and transform it automatically to KM3 or ecore and
inject it would
help extremely.
Mike
Re: XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD [message #98089 is a reply to message #98074] Thu, 22 January 2009 09:50 Go to previous messageGo to next message
Michael,
I installed xsd2ecore 2.4.1 from the EMF SDK update site.
If you create a new EMF model, you can choose create it from an XSD file.
However, the feature seems to be rather unstable, since it doesn't work
anymore for me at the moment.
If it works for you, would you like to share your eclipse configuration with
me? I've been experimenting with ATL and QVT in the same eclipse
installation, and things seem to be interfering with one another.
Bart Decuypere
Re: XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD [message #98440 is a reply to message #98089] Tue, 27 January 2009 03:54 Go to previous messageGo to next message
Hello Bart,
didn't try xsd2ecore yet but I made the XSD tutorial from
openArchitectureWare:
http://www.openarchitectureware.org/pub/documentation/4.3.1/ html/contents/xsd_tutorial.html
Adopted it to my project and it runs perfectly.
It can import XSD directly as metamodels.
Maybe this is something for you....?
Mike
Bart Decuypere wrote:
> Michael,
> Bart Decuypere
[ATL] Re: XSD -> Ecore -> XML <- ATL -> XML -> Ecore -> XSD [message #100031 is a reply to message #98440] Mon, 16 February 2009 03:54 Go to previous message
Michael Igler wrote:
> Hello Bart,
> Mike
>> Michael,
>> work anymore for me at the moment.
>> configuration with me? I've been experimenting with ATL and QVT in the
>> same eclipse installation, and things seem to be interfering with one
>> another.
>> Bart Decuypere
Some time ago, I've also worked with EMF-XSD and ATL. You can have a
look at my solution, in case it helps:
http://ssel.vub.ac.be/viewvc/hibernate-mapping-3.0/
Kind regards,
Dennis
Previous Topic:Test for oclUndefined and a rule that breaks the transformation
Next Topic:Obtain SQL schema from UML class diagram
Current Time: Sun Aug 31 04:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.03836 seconds
