[ATL] refining [message #97530] |
Thu, 08 January 2009 04:02  |
Hello everybody,
In refining mode, how can i copy exactely my input model to my output model ?
No need to write any rule ? just header ?
thank
Re: [ATL] refining [message #97576 is a reply to message #97544] |
Thu, 08 January 2009 09:53   |
sabatier a écrit :
> sabatier a écrit :
>> Hello everybody,
>> model ?
It will work with the latest version of ATL refining mode, available in
the next ATL 3.0 release.
>> thank
> I use last version of ATL in Topcased project.
Topcased includes the ATL 2.0 version, which contains the old refining
version. To copy a model with that version you will have to write a rule
transforming the root element, i.e. UML!Model for UML models, into itself.
This is one of the reason we now have a new refining mode. :-)
If you want to evaluate the 3.0 version, you can install the ATL 3.0.0M4
build, available here:
http://www.eclipse.org/modeling/m2m/downloads/index.php?proj ect=atl.
William
Re: [ATL] refining [message #97591 is a reply to message #97576] |
Fri, 09 January 2009 08:44   |
Thank you
it's all i want to know
Best regards
Laurent
William Piers a écrit :
> Hello,
> sabatier a écrit :
>> sabatier a écrit :
>>> Hello everybody,
>>> model ?
>>> thank
> Best regards,
> William
Re: [ATL] refining [message #105959 is a reply to message #101093] |
Tue, 02 June 2009 10:35  |
Lazy rule also doesn't seems works in refining mode in ATL 3.0
Miguel Llácer San Fernando a écrit :
> I have tried to use refining mode in ATL 2.0 and I haven't obtained
> expected results.
> By the other hand, I have update to ATL 3.0 in eclipse Ganymede 3.4 and
> I have tested public2private example and it works fine.
> But I have some questions:
> I have tried to use do block and an error appears (do block not
> supported in refining mode) and it occurrs the same with called rules
> (called rules not supported in refining mode yet).
> will we be able to use it in future ?¿?
FUDForum. Page generated in 0.26098 seconds
