Home » Eclipse Projects » Eclipse Platform » how to trap eclipse save action
how to trap eclipse save action [message #97495] Tue, 22 July 2003 12:55 Go to next message
Originally posted by: bhaskar.calavista.com
Hi All,
Is there any way of trapping Eclipse save action (when user clicks on
the Save button on the toolbar).
Bhaskar
Re: how to trap eclipse save action [message #97533 is a reply to message #97495] Tue, 22 July 2003 14:02 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
Maybe if you described what you are trying to do, we could provide possible
solutions to your problem
Simon :-)
"Bhaskar" <bhaskar@calavista.com> wrote in message
news:bfjq9i$glm$1@eclipse.org...
> Hi All,
> Bhaskar
Re: how to trap eclipse save action [message #97568 is a reply to message #97533] Tue, 22 July 2003 15:09 Go to previous messageGo to next message
Okay, here is what I am trying to do. I am trying to implement decorators.
Now when user modifies a resource and saves the modifications, I want to
show this change using decorators. For this I need to trap the save event
so that I can know when user modified the resource and what is the
resource name.
Hope I am clear this time.
Bhaskar
> Simon :-)
> > Hi All,
> > Thanks,
> > Bhaskar
Re: how to trap eclipse save action [message #97597 is a reply to message #97568] Tue, 22 July 2003 15:21 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Read this:
http://www.eclipsecorner.org/articles/Article-Decorators/dec orators.html
Pay attention to Redecorate section, also to listen for changes, use
IWorkspace.addResourceChangeListener(). Remember to remove yourself when
no longer needed.
Also don't add yourself as a startup plugin (you may think this is
necessary so that you can add yourself as a resource change listener,
but if you are using the decorators correctly you will be started when
necessary and can add yourself at that time).
Rich
Re: how to trap eclipse save action [message #97656 is a reply to message #97597] Tue, 22 July 2003 16:52 Go to previous messageGo to next message
Rich,
Thanks for the response. I already had read that article and my
redecoration is very similar to that explained in that article.
I am also using IWorkspace.addResourceChangeListener() but having
two problems:
1) It tells me about every change going in the workspace. Since I am only
interested in save events, is there any way of getting only this
informatiom through IWorkspace.addResourceChangeListener().
2) I was unable to get the name of the resource on which changes happened.
Everytime I used IResourceChangedEvent getResoource() method, I got null
in return.
What do u specifically mean by not adding my resource change listener
as a startup Plugin. Does that mean that I should not use my startup()
method of my main plugin class (CtkPlugin.java in my case) for registering
resource change listener class? If yes, then how will I get to know about
the changes?
One more problem....when I am using my decorators, every time some
decoration changes, the changes are not seen in the workspace. Only when
I again click on OK or apply in Windows>Preferences>Workbench>Label
decoration the changes appears on the workspace. Again, I have tried my
best to remain close to the methods described in the above mentioned
article. what could be wrong??
Bhaskar
Richard L. Kulp wrote:
> Read this:
> no longer needed.
> Rich
Re: how to trap eclipse save action [message #97730 is a reply to message #97656] Tue, 22 July 2003 19:10 Go to previous messageGo to next message
Bhaskar wrote:
> Rich,
> two problems:
> information through IWorkspace.addResourceChangeListener().
No, you can only specify notification during certain phases, such as
PRE_AUTO_BUILD or POST_CHANGE. You are probably most interested in
POST_BUILD. That way you won't get Close notifications. But you would be
interested in Adds (because this is then either a new resource or the
resource has been moved somewhere else, in either case you would want to
change the decoration, no?).
Really, how you process resource change events is complicated. See this:
http://www.eclipsecorner.org/articles/Article-Resource-delta s/resource-deltas.html
> Every time I used IResourceChangedEvent getResoource() method, I got null
> in return.
> the changes?
I meant don't use the startup extension point in the plugin.xml. This
extension point forces your plugin to be activated immediately on
startup of the entire workbench. You don't want to do that. Let Eclipse
determine that it is time to be activated.
You should still use your startup() method to listen to resource
changes, but your plugin won't be activated until necessary. And the
decoration mechanism can determine when to activate for you.
As shown in the article, your label decorator (which should be
light-weight decorator registered with workbench as I think yours is),
needs to fire a label change event whenever a resource needs to be
redecorated. Take a close look at the Redecorates section of the
article. You resource listener needs to fire this refresh against your
decorator when the resource changes. As in the example, there is an
exposed public method that says refresh(List). The List is a list of the
IResource's that have changed and need new decorations.
> Bhaskar
>>Read this:
>>no longer needed.
>>Rich
Thanks, Rich Kulp
Re: how to trap eclipse save action [message #97757 is a reply to message #97730] Tue, 22 July 2003 19:32 Go to previous messageGo to next message
Rich,
Thanks for the detailed reply. I just tried the POST_AUTO_BUILD of
IResourceChangeEvent Interface. Yes it is telling me the modifications of
the workspace but it is still not telling the name of the resource that
has been modified. I tried event.getResource().getName() but I am getting
a null pointer Exception (same is the problem with POST_CHANGE). Is there
any way of getting the resource name?
I will try ur decorators suggestions soon.
Bhaskar
> Bhaskar wrote:
> > Rich,
> > two problems:
> > in return.
> > the changes?
> > Thanks,
> > Bhaskar
Re: how to trap eclipse save action [message #97921 is a reply to message #97757] Wed, 23 July 2003 02:19 Go to previous messageGo to next message
Rich,
I just read
article. I am pretty sure that now I will be able to get the modified
resources (although I have not tried it yet). Thanks for it. Regarding
decorator thing, I am not implementing light weight decorators. Should I
do this to solve my problem. My problem was :
"when I am using my decorators, every time some decoration changes, the
changes are not seen in the workspace. Only when I again click on OK or
apply in Windows>Preferences>Workbench>Label decoration the changes
appears on the workspace. Again, I have tried my best to remain close to
the methods described in the above mentioned article. what could be
wrong??"
Ur response was:
right now I am refresing every resource (not the changed resource only). I
don't think that this could be the problem although it is pretty
inefficient. My refresh method is calling another method which fires the
refresh. But this firing, somehow, is unheard by DecorateImage() method.
How can this happen. Again eveything is similar to the example given in
decorators article.
Thanks once again for all ur responses.
Bhaskar
Bhaskar wrote:
> Rich,
> Bhaskar
Re: how to trap eclipse save action [message #98456 is a reply to message #97921] Wed, 23 July 2003 10:53 Go to previous messageGo to next message
You've reached the limit of my understanding. :-)
I've never actually implemented the decorators using the Eclipse
decorator manager. Maybe you should try the demo from the decorators
sample article and understand how that one works. Then it may give you
clues as to why yours isn't working.
Rich
Re: how to trap eclipse save action [message #98530 is a reply to message #98456] Wed, 23 July 2003 11:57 Go to previous message
Rich,
Sorry to say but I have already tried that DemoDecorator example given in
that article :-) . Anyways, thanks for taking out time for responding me.
I hope I should be able to do it today.
Bhaskar
> Rich
Previous Topic:Exporting plugins...
Next Topic:How to close a Perspective Programatically
Current Time: Thu Jul 24 01:14:59 EDT 2025
Powered by FUDForum. Page generated in 0.07196 seconds
