Home » Archived » M2M (model-to-model transformation) » [ATL] What's new in the 2.0.2 ATL version?
[ATL] What's new in the 2.0.2 ATL version? [message #97437] Wed, 31 December 2008 05:29 Go to next message
Does anybody know what is new in this new ATL version 2.0.2 (archived the
19 december 2008)?
Is it compatible with the 2.0.1 (september)?
Re: [ATL] What's new in the 2.0.2 ATL version? [message #97465 is a reply to message #97437] Mon, 05 January 2009 03:32 Go to previous messageGo to next message
The 2.0.2 version is a maintenance version of the ATL 2.0 release. This
build don't provide new features, but corrects some issues, i.e. a
packaging problem which was disabling the use of the ATL engine api by
third party plugins.
So it is fully compatible with 2.0.1, 2.0.0.
New features and enhancements will be provided by the 3.0.0 milestones.
At this time, the 3.0.0M4 is available (on the downloads page) and
mostly consists on an api refactoring.
William
Skander a écrit :
> the 19 december 2008)?
> Thanks
[ATL] ATL 3.0.0M4: example plugin doesn't work [message #97494 is a reply to message #97465] Mon, 05 January 2009 16:44 Go to previous messageGo to next message
Hello William,
I just tested the new ATL 3.0.0 M4 version with Eclipse 3.5 M4.
Unfortunately, the example ATL project
"org.eclipse.m2m.atl.examples.public2private.ui" doesn't work for me.
I launch a new Eclipse application (69 required plugins will be loaded),
create a new project and copy the "sample.uml" to the project.
Then I right-click on "sample.uml" and choose the menu-item
"Privatize public fields".
But nothing happens.
Deepak
> Best regards,
> William
Re: [ATL] ATL 3.0.0M4: example plugin doesn't work [message #97510 is a reply to message #97494] Tue, 06 January 2009 02:46 Go to previous messageGo to next message
This example also requires the UML2 plugin, did you install it?
Otherwise, does the transformation work when launching directly from
org.eclipse.m2m.atl.examples.public2private?
William
Deepak a écrit :
> Hello William,
> Deepak
>> milestones. At this time, the 3.0.0M4 is available (on the downloads
>> page) and mostly consists on an api refactoring.
>> Best regards,
>> William
Re: [ATL] ATL 3.0.0M4: example plugin doesn't work [message #97521 is a reply to message #97510] Tue, 06 January 2009 10:01 Go to previous messageGo to next message
Hi William,
Yes I installed the stable builds 3.0.0M4 of UML2 plugin by putting it
in the dropins folder.
The dropins folder contains the following M4 stable builds:
emf-xsd-SDK
emft-compare-SDK
mdt-uml2-SDK
orbit-S20081025033911
mdt-ocl-SDK
emf-validation-SDK
emf-transaction-SDK
Yes, org.eclipse.m2m.atl.examples.public2private works directly.
Those three ATL launch configurations do the correct transformations for
the sample.uml
Deepak
> Hello,
> William
> Deepak a écrit :
>> Hello William,
>> loaded), create a new project and copy the "sample.uml" to the project.
>> Regards,
>> Deepak
>>> Best regards,
>>> William
Re: [ATL] ATL 3.0.0M4: example plugin doesn't work [message #97559 is a reply to message #97521] Thu, 08 January 2009 09:41 Go to previous message
Strange, it works for me. But I noticed that the example action didn't
catch some errors.
You can try to modify the action yourself in order to catch any
exception thrown by the transformation, or wait for the next build.
Then we could know what goes wrong...
Deepak a écrit :
> Hi William,
> emf-xsd-SDK
> emft-compare-SDK
> mdt-uml2-SDK
Note that orbit is used by the releng system to build ATL, but the antlr
plugin is ever included in the ATL build, so for using ATL you don't
need to install orbit.
William
> mdt-ocl-SDK
> emf-validation-SDK
> emf-transaction-SDK
> the sample.uml
> Deepak
>> Hello,
>> Regards,
>> William
>> Deepak a écrit :
>>> Hello William,
>>> Regards,
>>> Deepak
>>>> Best regards,
>>>> William
Previous Topic:[ATL] Is toString() operation not working on Real type?
Next Topic:[ATL]pb with starter guide example - antlr/TokenStream
Current Time: Sat Jul 26 13:15:40 EDT 2025
Powered by FUDForum. Page generated in 0.04838 seconds
