[ATL] Is toString() operation not working on Real type? [message #97421] |
Mon, 29 December 2008 17:44  |
--------------050907040607080408020501
After some experiments, I have found that the toString() operation is
not defined for Real types in ATL, thus contradicting the statement in
the ATL User Manual
( http://www.eclipse.org/m2m/atl/doc/ATL_User_Manual%5Bv0.7%5D .pdf),
4.1.4.3: "The toString() operation, available for both the integer and
*real* data types returns a string representing the integer/real value"
I'm attaching a very simple example that can be use to reproduce the
issue, composed of a metamodel with a class using a Real attribute
(Dummy.ecore), a model conforming to it (dummy-sample.ecore) and a very
simple query ATL that just print the attributes (DummyQuery.atl).
When I execute the query I get:
INFO: attReal=OclUndefined
attInteger=12
attString=foo
but I expected to get:
INFO: attReal=3.14
attInteger=12
attString=foo
So, I'm doing something wrong (my experience with ATL is not too long :)
or actually is there a issue with toString() on Real type? In the later
case, is there any workaround, please?
Thanks!
Ferm
Re: [ATL] Is toString() operation not working on Real type? [message #97479 is a reply to message #97421] |
Mon, 05 January 2009 03:53  |
This is a bug, so I created one here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=259933
Thanks for reporting it.
William
Fermín Galán Márquez a écrit :
> the ATL User Manual
> attInteger=12
> attString=foo
> INFO: attReal=3.14
> attInteger=12
> attString=foo
> Thanks!
> Best regards,
> Fermín
FUDForum. Page generated in 0.03214 seconds
