Home » Archived » BIRT » Trying (and struggling) to make a BIRT viewer JSF component
| Trying (and struggling) to make a BIRT viewer JSF component [message #97380] |
Thu, 08 December 2005 09:52  |
Originally posted by: maspeli.deloitte.co.uk
We're trying to make a BIRT viewer that is a JavaServerFaces control. If all
goes well and this clears the right hurdles, we'll hopefully be able to
release this back into the community. However, I'm struggling a bit with
both the philosophy behind the API and with exceptions I don't know the
cause of.
Basically, I strated with the BIRT viewer example. My first problem is that
I can't seem to check this out from CVS (dev.eclipse.org won't let me
connect as pserver anonymous on /cvsroot/birt). I found the source with
ViewCVS, however, and I'm now trying to adapt this code to fit a JSF type
framework. I've pasted the relevant code below. Basically, I can now get the
report to open (I think), but I get the following exception, no matter what
I do:
javax.faces.FacesException: javax.servlet.jsp.JspException: The output
format html is not supported.
org.apache.myfaces.context.servlet.ServletExternalContextImp l.dispatch(Servl
etExternalContextImpl.java:421)
org.apache.myfaces.application.jsp.JspViewHandlerImpl.render View(JspViewHand
lerImpl.java:234)
org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleI mpl.java:352)
javax.faces.webapp.FacesServlet.service(FacesServlet.java:10 7)
org.apache.myfaces.component.html.util.ExtensionsFilter.doFi lter(ExtensionsF
ilter.java:122)
This happens as soon as I run the IRunAndRenderTask, no matter what I do. If
I do renderOption.setOutputFormat("foobar") I get "The output format foobar
is not supported", so it's clearly picking up the format. Also, even if I
try to set the output stream in renderOption to e.g. a
ByteArrayOutputStream, I still get the error.
The documentation for ExternalContext reads:
public abstract void dispatch(java.lang.String path)
throws java.io.IOExceptionDispatch a request to the
specified resource to create output for this response.
Servlet: This must be accomplished by calling the
javax.servlet.ServletContext method getRequestDispatcher(path), and calling
the forward() method on the resulting object.
Portlet: This must be accomplished by calling the
javax.portlet.PortletContext method getRequestDispatcher(), and calling the
include() method on the resulting object.
Parameters:
path - Context relative path to the specified resource, which must start
with a slash ("/") character
Throws:
FacesException - thrown if a ServletException or PortletException occurs
java.lang.IllegalArgumentException - if no request dispatcher can be
created for the specified path
java.lang.IllegalStateException - if this method is called in a portlet
environment, and the current request is an ActionRequest instead of a
RenderRequest
java.io.IOException - if an input/output error occurs
java.lang.NullPointerException - if path is null
A few points:
- my WEB-INF/lib contains everything the M3 runtime Web Viewer Example's
- I haven't set BIRT_HOME, I'm not sure if this is required for this
scenaro.
- I've re-implemented the ReportEngineService, PlatformServletContext and
ParameterAccessor from the example to work with JSF. The code is below.
Any help or background would be greatly appreciated!
---> The handler for the component that actually renders the report <---
package uk.gov.tfl.lez.view.components.birtviewer;
import java.io.ByteArrayOutputStream;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import javax.faces.application.Application;
import javax.faces.component.UIComponentBase;
import javax.faces.context.ExternalContext;
import javax.faces.context.FacesContext;
import javax.faces.context.ResponseWriter;
import javax.servlet.ServletContext;
import javax.servlet.ServletException;
import javax.servlet.ServletOutputStream;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import org.eclipse.birt.core.exception.BirtException;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.HTMLRenderContext;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.HTMLServerImageHandler;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IRenderOption;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
public class BIRTViewer extends UIComponentBase implements IBIRTViewer {
public static final String COMPONENT_TYPE = "uk.gov.tfl.lez.BIRTViewer";
public static final String COMPONENT_FAMILY = "uk.gov.tfl.lez.BIRTFamily";
public String getFamily() {
return COMPONENT_FAMILY;
public void encodeBegin(FacesContext context) throws IOException {
if (!isRendered())
return;
Application application = context.getApplication();
ExternalContext externalContext = context.getExternalContext();
String contextPath = externalContext.getRequestContextPath();
// XXX: We'd rather not do this briding. We could probably write a new
// implementation of IPlatformContext that operates on an ExternalContext
ServletContext servletContext = (ServletContext)
externalContext.getContext();
HttpServletRequest request = (HttpServletRequest)
externalContext.getRequest();
Map attributes = getAttributes();
String design = (String) attributes.get("design");
HashMap params;
try {
params = (HashMap) attributes.get("params");
} catch (ClassCastException e) {
params = new HashMap();
// Get the report engine via the ReportEngineService singleton wrapper
// XXX: This API is dumb. Fix it.
ReportEngineService.initEngineInstance(externalContext);
ReportEngineService engineService = ReportEngineService.getInstance();
// XXX: Need to initialise engine context and params context globally, not
per request like this!
ParameterAccessor.initParameters(servletContext);
engineService.setEngineContext(externalContext, request);
// Open the report from the filename provided
IReportRunnable report = engineService.openReportDesign(design);
// Parameters
// XXX: Need to parse parameters
// IGetParameterDefinitionTask parameterTask =
engineService.createGetParameterDefinitionTask(report);
// HashMap parameterMap = parseParameters(request, parameterTask,
report.getTestConfig());
// Collection parameterMap = parameterTask.getParameterDefns(true);
// Set render options - this tells BIRT where and how to render (in our
case, HTML to the response)
IRenderOption renderOption = new HTMLRenderOption();
renderOption.setOutputStream(context.getResponseStream());
renderOption.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_ HTML);
// Create the run-and-render task to allow us to execute the rendering
IRunAndRenderTask runTask = engineService.createRunAndRenderTask(report);
runTask.setLocale(application.getDefaultLocale());
runTask.setParameterValues(params);
runTask.setRenderOption(renderOption);
// Create render context - the renderer needs to write some files to a
working directory
// and needs to know how to do so.
HTMLRenderContext renderContext = new HTMLRenderContext();
renderContext.setImageDirectory(engineService.getImageDirect ory());
renderContext.setBaseImageURL(contextPath +
engineService.getImageBaseUrl());
renderContext.setBaseURL(contextPath);
renderContext.setSupportedImageFormats("PNG;GIF;JPG;BMP");
HashMap contextMap = new HashMap();
contextMap.put(EngineConstants.APPCONTEXT_HTML_RENDER_CONTEX T,
renderContext);
runTask.setAppContext(contextMap);
// Finally, run the report, then clean up
try {
runTask.run();
} catch (BirtException e) {
throw new IOException(e.getLocalizedMessage());
} finally {
runTask.close();
---> ReportEngineService.java <----
* Copyright (c) 2004 Actuate Corporation and others.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Actuate Corporation - Initial implementation.
import java.io.InputStream;
import java.rmi.RemoteException;
import java.util.Locale;
import java.util.logging.Level;
import org.eclipse.birt.core.framework.IPlatformContext;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.HTMLActionHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.IRenderTask;
import org.eclipse.birt.report.engine.api.IReportDocument;
import org.eclipse.birt.report.engine.api.IRunTask;
import org.eclipse.birt.report.engine.api.ReportEngine;
import uk.gov.tfl.lez.view.components.birtviewer.PlatformFacesConte xt;
public class ReportEngineService {
private static ReportEngineService instance;
* Report engine instance.
private ReportEngine engine = null;
* Static engine config instance.
private EngineConfig config = null;
* Image directory for report images and charts.
private String imageDirectory = null;
* URL accesses images.
private String imageBaseUrl = null;
* Web app context path.
private String contextPath = null;
* Image handler instance.
private HTMLServerImageHandler imageHandler = null;
protected ReportEngineService() {
* Get engine instance.
* @return
synchronized public static ReportEngineService getInstance() {
if(instance == null)
throw new IllegalStateException("You must call initEngineInstance()
before using getInstance()!");
return instance;
* Initialise engine instance.
* @param context The external context of the JSF
* @return engine instance
synchronized public static void initEngineInstance(ExternalContext context)
instance = new ReportEngineService();
instance.configureInstance(context);
synchronized private void configureInstance(ExternalContext context) {
config = new EngineConfig();
// XXX: Would rather not have to do this, but getRealPath() means we must
ServletContext servletContext = (ServletContext) context.getContext();
// Register new image handler
HTMLEmitterConfig emitterConfig = new HTMLEmitterConfig();
emitterConfig.setActionHandler(new HTMLActionHandler());
imageHandler = new HTMLServerImageHandler();
emitterConfig.setImageHandler(imageHandler);
config.setEmitterConfiguration(HTMLRenderOption.OUTPUT_FORMA T_HTML,
emitterConfig);
// Prepare image directory.
imageDirectory =
context.getInitParameter(ParameterAccessor.INIT_PARAM_IMAGE_ DIR);
if (imageDirectory == null || imageDirectory.trim().length() <= 0
|| ParameterAccessor.isRelativePath(imageDirectory)) {
imageDirectory = servletContext.getRealPath("/report/images");
// Prepare image base url.
imageBaseUrl = "/run?__imageID=";
// Prepare log directory.
String logDirectory =
context.getInitParameter(ParameterAccessor.INIT_PARAM_LOG_DI R);
if (logDirectory == null || logDirectory.trim().length() <= 0 ||
ParameterAccessor.isRelativePath(logDirectory)) {
logDirectory = servletContext.getRealPath("/logs");
// Prepare log level.
String logLevel =
servletContext.getInitParameter(ParameterAccessor.INIT_PARAM _LOG_LEVEL);
Level level = Level.OFF;
if ("SEVERE".equalsIgnoreCase(logLevel)) {
level = Level.SEVERE;
} else if ("WARNING".equalsIgnoreCase(logLevel)) {
level = Level.WARNING;
} else if ("INFO".equalsIgnoreCase(logLevel)) {
level = Level.INFO;
} else if ("CONFIG".equalsIgnoreCase(logLevel)) {
level = Level.CONFIG;
} else if ("FINE".equalsIgnoreCase(logLevel)) {
level = Level.FINE;
} else if ("FINER".equalsIgnoreCase(logLevel)) {
level = Level.FINER;
} else if ("FINEST".equalsIgnoreCase(logLevel)) {
level = Level.FINEST;
} else if ("OFF".equalsIgnoreCase(logLevel)) {
level = Level.OFF;
config.setLogConfig(logDirectory, level);
* Set Engine context.
* @param servletContext
* @param request
synchronized public void setEngineContext(ExternalContext externalContext,
HttpServletRequest request) {
// XXX: Would rather not have to depend on HttpServletRequest here
if (engine == null) {
String url = request.getRequestURL().toString();
this.contextPath = request.getContextPath();
url = url.substring(0, url.indexOf(contextPath, url.indexOf("/"))) +
contextPath;
config.setEngineHome("");
IPlatformContext context = new PlatformFacesContext(externalContext,
url);
config.setEngineContext(context);
engine = new ReportEngine(config);
* Open report design.
* @param report
* @return
synchronized public IReportRunnable openReportDesign(String report) {
IReportRunnable runnable = null;
try {
runnable = engine.openReportDesign(report);
} catch (Exception e) {
throw new IllegalStateException("Could not open report design " + report
+ ".", e);
return runnable;
* @param report
* @return
synchronized public IReportRunnable openReportDesign(InputStream stream) {
try {
runnable = engine.openReportDesign(stream);
return runnable;
* createGetParameterDefinitionTask.
* @param runnable
* @return
synchronized public IGetParameterDefinitionTask
createGetParameterDefinitionTask(IReportRunnable runnable) {
IGetParameterDefinitionTask task = null;
try {
task = engine.createGetParameterDefinitionTask(runnable);
return task;
* createRunAndRenderTask.
* @param runnable
* @return
synchronized public IRunAndRenderTask
createRunAndRenderTask(IReportRunnable runnable) {
IRunAndRenderTask task = null;
assert runnable != null;
try {
task = engine.createRunAndRenderTask(runnable);
throw new IllegalStateException("Cannot create run-and-render task", e);
return task;
* Open report document from archive,
* @param docName - the name of the report document
* @return
synchronized public IReportDocument openReportDocument(String docName) {
IReportDocument document = null;
try {
document = engine.openReportDocument(docName);
return document;
* Run report.
* @param runnable
* @param archive
* @param documentName
* @param locale
* @param parameters
* @throws RemoteException
synchronized public void runReport(IReportRunnable runnable, String
documentName,
Locale locale, HashMap parameters) throws RemoteException {
// Preapre the run report task.
IRunTask runTask = engine.createRunTask(runnable);
runTask.setLocale(locale);
runTask.setParameterValues(parameters);
// Run report.
try {
runTask.run(documentName);
throw new RemoteException("BIRT Report Engine", e);
} finally {
runTask.close();
* Render report page.
* @param reportDocument
* @param pageNumber
* @param svgFlag
* @return report page content
synchronized public ByteArrayOutputStream renderReport(IReportDocument
reportDocument, long pageNumber, boolean svgFlag)
assert reportDocument != null;
assert pageNumber >= 0;
ByteArrayOutputStream out = new ByteArrayOutputStream();
// Create render task.
IRenderTask renderTask = engine.createRenderTask(reportDocument);
// Render context
renderContext.setImageDirectory(imageDirectory);
renderContext.setBaseImageURL(contextPath + imageBaseUrl);
renderContext.setSupportedImageFormats(svgFlag ? "PNG;GIF;JPG;BMP;SVG" :
"PNG;GIF;JPG;BMP"); //$NON-NLS-2$
renderContext.setBaseURL(this.contextPath + "/frameset");
renderContext);
renderTask.setAppContext(contextMap);
// Render option
HTMLRenderOption setting = new HTMLRenderOption();
setting.setOutputStream(out);
setting.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_HTML) ;
setting.setEmbeddable(true);
renderTask.setRenderOption(setting);
// Render designated page.
try {
renderTask.render(pageNumber);
} finally {
renderTask.close();
return out;
* @return Returns the imageBaseUrl.
public String getImageBaseUrl() {
return imageBaseUrl;
* @return Returns the imageDirectory.
public String getImageDirectory() {
return imageDirectory;
* @return Returns the imageHandler.
public HTMLServerImageHandler getImageHandler() {
return imageHandler;
* @return Returns the contextPath.
public String getContextPath() {
return contextPath;
---> ParameterAccessor.java <---
* Contributors:
* Deloitte MCS - Modifications for use with BIRTViewer JSF component
import java.io.File;
import java.io.UnsupportedEncodingException;
import java.net.URLEncoder;
import java.util.Enumeration;
import java.util.HashSet;
import java.util.Iterator;
import java.util.Set;
* Utilities for URI-related operations
public class ParameterAccessor {
* URL parameter names.
public static final String PARAM_REPORT = "__report";
public static final String PARAM_REPORT_DOCUMENT = "__document";
public static final String PARAM_FORMAT = "__format";
public static final String PARAM_FORMAT_HTML = "html";
public static final String PARAM_FORMAT_PDF = "pdf";
public static final String PARAM_LOCALE = "__locale";
public static final String PARAM_SVG = "__svg";
public static final String PARAM_PAGE = "__page";
public static final String PARAM_ISNULL = "__isnull";
public static final String PARAM_USETESTCONFIG = "__usetestconfig";
public static final String PARAM_IMAGEID = "__imageID";
* Servlet configuration parameter names.
public static final String INIT_PARAM_LOCALE = "BIRT_VIEWER_LOCALE";
public static final String INIT_PARAM_REPORT_DIR =
"BIRT_VIEWER_WORKING_FOLDER";
public static final String INIT_PARAM_IMAGE_DIR = "BIRT_VIEWER_IMAGE_DIR";
public static final String INIT_PARAM_LOG_DIR = "BIRT_VIEWER_LOG_DIR";
public static final String INIT_PARAM_LOG_LEVEL = "BIRT_VIEWER_LOG_LEVEL";
* Report working folder.
private static String workingFolder = null;
* Current web application locale.
private static Locale webAppLocale = null;
* Initial the parameters class. Web.xml is in UTF-8 format. No need to do
* encoding convertion.
* @param config
public synchronized static void initParameters(ServletContext context) {
// Report root.in the web.xml has higher priority.
workingFolder = context.getInitParameter(INIT_PARAM_REPORT_DIR);
if (workingFolder == null || workingFolder.trim().length() <= 0) {
// Use birt dir as default report root.
workingFolder = context.getRealPath("/");
// Report root could be empty .WAR
// Clear out report location.
if (workingFolder != null &&
workingFolder.trim().endsWith(File.separator)) {
workingFolder = workingFolder.trim().substring(0,
workingFolder.trim().length() - 1);
webAppLocale =
getLocaleFromString(context.getInitParameter(INIT_PARAM_LOCA LE));
* Get report file name.
* @param request
* http request
* @return report file name
public static String getReport(HttpServletRequest request) {
String fileName = getParameter(request, PARAM_REPORT);
if (fileName == null) {
fileName = "";
} else {
fileName = fileName.trim();
// Get absolute report location.
if (isRelativePath(fileName)) {
if (fileName.startsWith(File.separator)) {
fileName = workingFolder + fileName;
} else {
fileName = workingFolder + File.separator + fileName;
return fileName;
* Get report document name.
* @param request
* http request
public static String getReportDocument(HttpServletRequest request) {
String fileName = getParameter(request, PARAM_REPORT_DOCUMENT);
fileName = "";
} else {
if (fileName != null && fileName.length() > 0) {
} else {
return fileName;
* Checks if a given file name contains relative path.
* @param fileName
* The file name.
* @return A <code>boolean</code> value indicating if the file name
* contains relative path or not.
public static boolean isRelativePath(String fileName) {
if (File.separatorChar == '\\') {
// Win32
return fileName != null && fileName.indexOf(':') <= 0;
} else if (File.separatorChar == '/') {
// Unix
return fileName != null && !fileName.startsWith("/");
return false;
* Get report format.
* @param request
* http request
* @return report format
public static String getFormat(HttpServletRequest request) {
String format = getParameter(request, PARAM_FORMAT);
if (format != null && format.length() > 0) {
return format;
return PARAM_FORMAT_HTML; // The default format is html.
* Get report locale from Http request.
* @param request
* http request
* @return report locale
public static Locale getLocale(HttpServletRequest request) {
return getLocaleFromString(getParameter(request, PARAM_LOCALE));
* Get report page from Http request.
* @param request
* http request
public static int getPage(HttpServletRequest request) {
int iPage = 1;
String page = getParameter(request, PARAM_PAGE);
if (page != null && page.length() > 0) {
try {
iPage = Integer.parseInt(page);
} catch (NumberFormatException ex) {
iPage = 1;
iPage = iPage < 0 ? 1 : iPage;
return iPage; // The default page value is 0.
* Get web application locale.
public static Locale getWebAppLocale() {
return webAppLocale;
* Check whether enable svg support or not.
* @param request
* http request
* @return whether or not render content toolbar
public static boolean getSVGFlag(HttpServletRequest request) {
boolean svg = true;
if ("false".equalsIgnoreCase(getParameter(request, PARAM_SVG))) {
svg = false;
return svg;
* Get report locale from a given string.
* @param locale
* locale string
public static Locale getLocaleFromString(String locale) {
if (locale == null || locale.length() <= 0) {
return Locale.getDefault();
int index = locale.indexOf('_');
if (index != -1) {
String language = locale.substring(0, index);
String country = locale.substring(index + 1);
return new Locale(language, country);
return new Locale(locale);
* Get report locale in string.
* @param request
* http request
* @return report String
public static String getLocaleString(HttpServletRequest request) {
return getParameter(request, PARAM_LOCALE);
* Check whether viewer should take values from report's test config.
* @param request
* http request
* @return whether or not take values from report's test config.
public static boolean isUseTestConfig(HttpServletRequest request) {
boolean isUseTestConfig = false;
if ("true".equalsIgnoreCase(getParameter(request, PARAM_USETESTCONFIG))) {
isUseTestConfig = true;
return isUseTestConfig;
* Get report parameter by given name.
* @param request
* http request
* @param name
* parameter name
* @param defaultValue
* default parameter value
* @return parameter value
public static String getReportParameter(HttpServletRequest request,
String name, String defaultValue) {
String value = getParameter(request, name);
if (value == null || ((String) value).trim().length() <= 0) {
value = "";
Map paramMap = request.getParameterMap();
String ISOName = toISOString(name);
if (paramMap == null || !paramMap.containsKey(ISOName)) {
value = defaultValue;
Set nullParams = getParameterValues(request, PARAM_ISNULL);
if (nullParams != null && nullParams.contains(name)) {
value = null;
return value;
* Check whether report parameter exists in the url.
* @param request
* http request
* @param name
* parameter name
* @return whether report parameter exists in the url
public static boolean isReportParameterExist(HttpServletRequest request,
String name) {
assert request != null && name != null;
boolean isExist = false;
if (paramMap != null && paramMap.containsKey(ISOName)) {
isExist = true;
isExist = true;
return isExist;
* Get query string with new parameter value.
* @param request
* http request
* @param name
* parameter name
* @param value
* @return new query string with new parameter value
public static String getEncodedQueryString(HttpServletRequest request,
String name, String value) {
String queryString = "";
Enumeration e = request.getParameterNames();
boolean isFirst = true;
while (e.hasMoreElements()) {
String paramName = (String) e.nextElement();
if (paramName != null && !paramName.equalsIgnoreCase(PARAM_ISNULL)) {
String paramValue = getParameter(request, paramName, false);
&& nullParams.remove(toUTFString(paramName))
&& !paramName.equalsIgnoreCase(name)) // Parameter
// value is
// null.
paramName = urlEncode(paramName, "ISO-8859-1");
queryString += (isFirst ? "" : "&") + PARAM_ISNULL + "=" + paramName;
//$NON-NLS-2$ //$NON-NLS-3$
isFirst = false;
continue;
if (paramName.equalsIgnoreCase(name)) {
paramValue = value;
paramValue = urlEncode(paramValue, "UTF-8");
queryString += (isFirst ? "" : "&") + paramName + "=" + paramValue;
isFirst = false;
if (nullParams != null && nullParams.size() > 0) {
Iterator i = nullParams.iterator();
while (i.hasNext()) {
String paramName = (String) i.next();
if (paramName != null && !paramName.equalsIgnoreCase(name)) {
paramName = urlEncode(paramName, "UTF-8");
isFirst = false;
if (getParameter(request, name) == null) {
String paramValue = value;
queryString += (isFirst ? "" : "&") + name + "=" + paramValue;
isFirst = false;
return queryString;
* Get named parameter from http request. parameter names and values are
all
* in iso-8859-1 format in request.
* @param request
* incoming http request
* @param parameterName
* parameter name in UTF-8 format
* @return
private static String getParameter(HttpServletRequest request,
String parameterName) {
return getParameter(request, parameterName, true);
all
* @param request
* parameter name
* @param isUTF
* is parameter in UTF-8 formator not
* @return
String parameterName, boolean isUTF) {
String ISOParameterName = (isUTF) ? toISOString(parameterName)
: parameterName;
return toUTFString(request.getParameter(ISOParameterName));
* Get named parameters from http request. parameter names and values are
* all in iso-8859-1 format in request.
* @param request
* @return
private static Set getParameterValues(HttpServletRequest request,
return getParameterValues(request, parameterName, true);
* @param request
* parameter name
* @param isUTF
* @return
HashSet parameterValues = null;
: parameterName;
String[] ISOParameterValues = request
.getParameterValues(ISOParameterName);
if (ISOParameterValues != null) {
parameterValues = new HashSet();
for (int i = 0; i < ISOParameterValues.length; i++) {
parameterValues.add(toUTFString(ISOParameterValues[i]));
return parameterValues;
* Convert UTF-8 string into ISO-8895-1
* @param s
* UTF-8 string
* @return
private static String toISOString(String s) {
String ISOString = s;
if (s != null) {
try {
ISOString = new String(s.getBytes("UTF-8"), "ISO-8859-1"); //$NON-NLS-2$
} catch (UnsupportedEncodingException e) {
ISOString = s;
return ISOString;
* Convert ISO-8895-1 string into UTF-8
* @param s
* ISO-8895-1 string
* @return
private static String toUTFString(String s) {
String UTFString = s;
if (s != null) {
try {
UTFString = new String(s.getBytes("ISO-8859-1"), "UTF-8"); //$NON-NLS-2$
UTFString = s;
return UTFString;
* URL encoding based on incoming encoding format.
* @param s
* string to be encoded.
* @param format
* encoding format.
* @return
private static String urlEncode(String s, String format) {
assert "ISO-8859-1".equalsIgnoreCase(format) ||
"UTF-8".equalsIgnoreCase(format); //$NON-NLS-2$
String encodedString = s;
if (s != null) {
try {
encodedString = URLEncoder.encode(s, format);
encodedString = s;
return encodedString;
* Is request parameter a report parameter.
* @param paraName
* @return boolean
private static final boolean isReportParameter(String paraName) {
boolean isReportParameter = false;
if (paraName != null && paraName.trim().length() > 2
&& !paraName.substring(0, 2).equalsIgnoreCase("__")) {
isReportParameter = true;
return isReportParameter;
* Check whether the request is to get image.
* @param request
* http request
* @return is get image or not
public static boolean isGetImageOperator(HttpServletRequest request) {
String imageName = getParameter(request, PARAM_IMAGEID);
return imageName != null && imageName.length() > 0;
* This function is used to encode an ordinary string that may contain
* characters or more than one consecutive spaces for appropriate HTML
* display.
* @param s
* @return String
public static final String htmlEncode(String s) {
String sHtmlEncoded = "";
if (s == null) {
return null;
StringBuffer sbHtmlEncoded = new StringBuffer();
final char chrarry[] = s.toCharArray();
for (int i = 0; i < chrarry.length; i++) {
char c = chrarry[i];
switch (c) {
case '\t':
sbHtmlEncoded.append("	");
break;
case '\n':
sbHtmlEncoded.append("<br>");
break;
case '\r':
break;
case ' ':
break;
case '"':
sbHtmlEncoded.append(""");
break;
case '\'':
sbHtmlEncoded.append("'");
break;
case '<':
sbHtmlEncoded.append("<");
break;
case '>':
sbHtmlEncoded.append(">");
break;
case '`':
sbHtmlEncoded.append("`");
break;
case '&':
sbHtmlEncoded.append("&");
break;
default:
sbHtmlEncoded.append(c);
sHtmlEncoded = sbHtmlEncoded.toString();
return sHtmlEncoded;
* Get current working folder.
* @return Returns the workingFolder.
public static String getWorkingFolder() {
return workingFolder;
---> PlatformFacesContext.java <---
* Copyright (c) 2004 Actuate Corporation. All rights reserved. This program
and
* the accompanying materials are made available under the terms of the
Eclipse
* Public License v1.0 which accompanies this distribution, and is available
* Contributors: Actuate Corporation - initial API and implementation
* Deloitte MCS - Derivative for JSF implementation
import java.net.MalformedURLException;
import java.net.URL;
import java.util.ArrayList;
import java.util.List;
import java.util.logging.Logger;
import org.eclipse.birt.core.framework.PlatformServletContext;
* A platform context is used by the BIRT engine to load resources.
* Since in web environment WAR deployment, absolute file paths are not
available,
* we must use resource operations instead of file operations.
public class PlatformFacesContext implements IPlatformContext {
public ExternalContext context = null;
public String urlLeadingString = null; // The beginning of the path (e.g.
http://localhost:7001/birt).
private static final String directorySeparator = "/";
static protected Logger log =
Logger.getLogger(PlatformServletContext.class.getName());
public PlatformFacesContext(ExternalContext context, String
urlLeadingString) {
this.context = context;
this.urlLeadingString = urlLeadingString;
/* (non-Javadoc)
* @see org.eclipse.birt.core.framework.IPlatformContext#getFolderLi st(
String homeFolder, String subFolder )
public List getFileList(String homeFolder, String subFolder, boolean
includingFiles, boolean relativeFileList) {
List folderList = new ArrayList();
String folderString = homeFolder;
if ((subFolder != null) && (subFolder.length() > 0) &&
!subFolder.equals("/")) {
folderString = concatFolderString(folderString, subFolder);
} else if (folderString.length() == 0 && subFolder.length() != 0) {
folderString = subFolder;
log.log(Level.WARNING, "Resouce paths with " + folderString + ", " +
homeFolder + ", " + subFolder);
Set files = context.getResourcePaths(folderString);
if ((files != null) && (files.size() > 0)) {
for (Iterator it = files.iterator(); it.hasNext();) {
Object obj = it.next();
if (!(obj instanceof String))
continue;
String pluginPath = (String) obj;
if (includingFiles || hasChildren(pluginPath)) // Simulate
File.isDirectory()
String pathString = pluginPath;
if (relativeFileList) {
// We assume the first part of pathString is homeFolder.
pathString = pathString.substring(homeFolder.length());
if (!pathString.startsWith(directorySeparator))
pathString = directorySeparator + pathString;
folderList.add(pathString);
return folderList;
* Simulate File.isDirectory()
* @param path - the relative path to check
* @return whether the element specified by path has children or not.
private boolean hasChildren(String path) {
Set children = context.getResourcePaths(path);
return ((children != null) && (children.size() > 0));
/* (non-Javadoc)
* @see org.eclipse.birt.core.framework.IPlatformContext#getInputStr eam(
String folder, String fileName )
public InputStream getInputStream(String folder, String fileName) {
InputStream in = null;
String file = concatFolderString(folder, fileName);
in = context.getResourceAsStream(file);
return in;
/* (non-Javadoc)
* @see org.eclipse.birt.core.framework.IPlatformContext#getURL( String
public URL getURL(String folder, String fileName) {
URL url = null;
try {
String fullFileString = concatFolderString(folder, fileName);
// XXX: Would rather not have to do this!
String realPath = servletContext.getRealPath(fullFileString);
if (realPath == null) {
/* We can not use context.getResource, because,
* although ServletContext.getResource can return a URL, in WAR
deployment,
* the URL (e.g.
zip:D:/bea8.1/user_projects/domains/mydomain/myserver/upload /birt.war!/WEB-I
NF/plugins/org.eclipse.birt.report.engine.emitter.html/htmlE mitter.jar)
* can not be recognized by URLClassLoader. So we decided to use the
full URL path like
http://localhost:7001/birt/plugins/org.eclipse.birt.report.e ngine.emitter.html/htmlEmitter.jar
instead,
* which can be used by URLClassLoader can load the class.
* The first part (http://localhost:7001/birt) will be provided by
viewer and passed into the engine.
* The engine will append the second part to make it a full valid URL.
url = new URL(urlLeadingString + fullFileString);
log.log(Level.FINE, "getResource({0}, {1}) returns {2}",
new Object[] { folder, fileName, realPath });
} else {
url = new File(realPath).toURL();
log.log(Level.FINE, "getRealPath({0}, {1}) returns {2}",
} catch (MalformedURLException e) {
e.printStackTrace();
return url;
private String concatFolderString(String parentString, String childString)
if (parentString == null)
return childString;
else if (childString == null)
return parentString;
if (!parentString.endsWith(directorySeparator)) {
parentString += directorySeparator;
if (childString.startsWith(directorySeparator)) {
childString = childString.substring(1);
return parentString + childString;
| Re: Trying (and struggling) to make a BIRT viewer JSF component [message #97508 is a reply to message #97380] |
Thu, 08 December 2005 12:17   |
Okay, this error had to do with the BIRT_HOME. I copied the 'plugins'
directory to my WebRoot and set the engine home accordingly. Reports now
render, but I see three problems:
- It renders the entire HTML page, including the DOCTYPE, <HTML> etc. Is
there some way around this in the API? I can always use regexps to clean it,
but it's a bit annoying.
- I have an embedded image in my test report. This gets rendered as an
empty <img> tag, no attributes, no nothing. This is using
HTMLServerImageHandler. I haven't really done anything to handle images, so
I'd expected they may be broken, but I would've thought the <img> tag output
with the report should point to *something*!
- If I try to run a report that accesses our MySQL database, I get an
exception. The mysql JDBC connector is in the WEB-INF/lib directory of the
deployment, and is working with Hibernate and works with the standalone
birt.war viewer (as do images, by the way). The exception is:
ERROR - Servlet.service() for servlet jsp threw exception
java.lang.NoClassDefFoundError:
org/eclipse/birt/data/oda/util/manifest/DtpManifestExplorer
org.eclipse.birt.report.model.extension.oda.ODAManifestUtil. getDataSourceExt
ension(ODAManifestUtil.java:40)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eODADataSourceEx
tensionID(OdaDataSourceState.java:105)
org.eclipse.birt.report.model.parser.OdaDataSourceState.pars eAttrs(OdaDataSo
urceState.java:55)
org.eclipse.birt.report.model.parser.ModuleParserHandler.sta rtElement(Module
ParserHandler.java:159)
at org.apache.xerces.parsers.AbstractSAXParser.startElement(Unk nown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanSt artElement(Unkno
wn Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$Fragme ntContentDispatc
her.dispatch(Unknown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDo cument(Unknown
Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:375)
org.eclipse.birt.report.model.parser.ModuleReader.readModule (ModuleReader.ja
va:89)
va:171)
org.eclipse.birt.report.model.parser.DesignReader.read(Desig nReader.java:135
org.eclipse.birt.report.model.core.DesignSession.openDesign( DesignSession.ja
va:175)
org.eclipse.birt.report.model.api.SessionHandle.openDesign(S essionHandle.jav
a:133)
org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportPar
ser.java:93)
org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(
ReportEngineHelper.java:103)
org.eclipse.birt.report.engine.api.ReportEngine.openReportDe sign(ReportEngin
e.java:220)
uk.gov.tfl.lez.view.components.birtviewer.ReportEngineServic e.openReportDesi
gn(ReportEngineService.java:200)
uk.gov.tfl.lez.view.components.birtviewer.BIRTViewer.encodeB egin(BIRTViewer.
java:139)
at javax.faces.webapp.UIComponentTag.encodeBegin(UIComponentTag .java:337)
at javax.faces.webapp.UIComponentTag.doStartTag(UIComponentTag. java:224)
org.apache.jsp.testing.component_jsp._jspx_meth_hlez_report_ 0(org.apache.jsp
..testing.component_jsp:307)
org.apache.jsp.testing.component_jsp._jspx_meth_f_subview_0( org.apache.jsp.t
esting.component_jsp:282)
org.apache.jsp.testing.component_jsp._jspx_meth_tiles_put_4( org.apache.jsp.t
esting.component_jsp:246)
org.apache.jsp.testing.component_jsp._jspx_meth_tiles_insert _0(org.apache.js
p.testing.component_jsp:129)
org.apache.jsp.testing.component_jsp._jspService(org.apache. jsp.testing.comp
onent_jsp:78)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.ja va:97)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.apache.jasper.servlet.JspServletWrapper.service(JspServl etWrapper.java:3
22)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServl et.java:314)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java :264)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(Application
FilterChain.java:252)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterCh
ain.java:173)
org.apache.catalina.core.ApplicationDispatcher.invoke(Applic ationDispatcher.
java:672)
org.apache.catalina.core.ApplicationDispatcher.processReques t(ApplicationDis
patcher.java:463)
org.apache.catalina.core.ApplicationDispatcher.doForward(App licationDispatch
er.java:398)
org.apache.catalina.core.ApplicationDispatcher.forward(Appli cationDispatcher
..java:301)
etExternalContextImpl.java:415)
lerImpl.java:234)
at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleI mpl.java:352)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:10 7)
ain.java:173)
ilter.java:122)
FilterChain.java:202)
ain.java:173)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.ja
va:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.ja
va:178)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:126
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:105
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java
:107)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:148)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:868)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processC
onnection(Http11BaseProtocol.java:663)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.jav
a:527)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWo
rkerThread.java:80)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.jav
a:684)
at java.lang.Thread.run(Thread.java:595)
ERROR - Servlet.service() for servlet Faces Servlet threw exception
lerImpl.java:234)
ain.java:173)
ilter.java:122)
ain.java:173)
va:213)
va:178)
:107)
a:527)
rkerThread.java:80)
a:684)
Caused by: javax.servlet.ServletException:
org.apache.jasper.runtime.PageContextImpl.doHandlePageExcept ion(PageContextI
mpl.java:848)
org.apache.jasper.runtime.PageContextImpl.handlePageExceptio n(PageContextImp
l.java:781)
onent_jsp:87)
22)
ain.java:173)
java:672)
patcher.java:463)
er.java:398)
..java:301)
.... 20 more
The current state of my code is below (ParameterAccessor.java is unchanged,
so I've left it out)
---> Code to render the report <---
if (!isRendered())
return;
// ExternalContext
// XXX: Debug
design =
servletContext.getRealPath("/birt/EuroClassBoundaries.rptdesign ");
HashMap params;
try {
ResponseWriter writer = context.getResponseWriter();
ReportEngineService.initEngineInstance(externalContext, request);
// not per request like this!
// Parameters
// engineService.createGetParameterDefinitionTask(report);
// report.getTestConfig());
// case, HTML to the response)
renderOption.setOutputStream(out);
// runTask.setLocale(application.getDefaultLocale());
// working directory and needs to know how to do so.
renderContext);
try {
runTask.run();
throw new IllegalStateException("Error whilst running report",
e.getCause());
} finally {
runTask.close();
out.flush();
writer.write(out.toString());
* Contributors:
* @return
return instance;
synchronized public static void initEngineInstance(ExternalContext context,
instance.configureInstance(context, request);
synchronized private void configureInstance(ExternalContext context,
log.log(Level.INFO, "configuring reportengineservice instance");
// XXX: We'd rather not be dependent on servlet context and http request
contextPath;
IPlatformContext platformContext = new PlatformFacesContext(context, url);
config.setEngineContext(platformContext);
log.log(Level.INFO, "created platform context on " + url);
// XXX: Is it necessary to set engine home? If so, externalise this to
web.xml
String engineHome = "/birt";
config.setEngineHome(engineHome);
log.log(Level.INFO, "set engine home to " + engineHome);
emitterConfig);
log.log(Level.INFO, "set emitter configuration to emit HTML");
imageDirectory =
if (imageDirectory == null || imageDirectory.trim().length() <= 0 ||
log.log(Level.INFO, "set image directoy to " + imageDirectory);
// XXX: Need to handle images properly!
log.log(Level.INFO, "set image directoy to " + logDirectory);
String logLevel =
level = Level.INFO;
level = Level.FINE;
level = Level.OFF;
log.log(Level.INFO, "set log level to " + level);
log.log(Level.INFO, "created engine");
* @param report
* @return
try {
+ ".", e);
return runnable;
* @param report
* @return
try {
return runnable;
* @param runnable
* @return
try {
return task;
* @param runnable
* @return
try {
return task;
* @return
try {
return document;
* Run report.
* @param runnable
* @param archive
* @param locale
* @param parameters
documentName,
// Run report.
try {
} finally {
runTask.close();
* @param pageNumber
* @param svgFlag
// Render context
renderContext);
// Render option
try {
} finally {
renderTask.close();
return out;
return contextPath;
Thanks again for any help!
Martin
| Re: Trying (and struggling) to make a BIRT viewer JSF component [message #97628 is a reply to message #97508] |
Thu, 08 December 2005 13:58   |
I'm sorry for the monologue here, but hopefully this is useful to other
people as well (and will be if we manage to release this).
it,
Still have this problem and would love a decent solution not involving
regexp replace.
so
output
Strangely, this stopped happening. I don't know what I did, but it works.
I've made a simple servlet that serves up images from the BIRT image
handler, and it seems to work fine.
One thing I am confused about - the BIRT runtime web app viewer gets my
images in its images/ directory and they seem to stay there. The images/
directory I've configured for my application is empty, even though images
are bein served. I use the HTMLServerImageHandler and it's writing straight
to the request in my servlet, so I suppose this is to be expected, but I'd
like to know why the birt.war application gets them and I don't. :)
I found some documentation that told me to update my plugin.xml and now it
works. Great!
So - I have a working report viewer, albeit one that spits out rather too
much HTML. It doesn't do parameters yet, though - that's step two. :)
Martin
| Re: Trying (and struggling) to make a BIRT viewer JSF component [message #101331 is a reply to message #97628] |
Wed, 21 December 2005 16:23  |
Martin,
Sorry I didnt see this earlier.
This may be to late, but there is a option in the HTMLRenderOption class to
set embeddable.
This turns off the <HTML> tag. Probably to late, but wanted to let you
know.
Jason Weathersby
BIRT PMC
"Martin Aspeli" <maspeli@deloitte.co.uk> wrote in message
news:dn9voq$odi$1@news.eclipse.org...
> it,
> regexp replace.
> so
> output
> straight
>> the
> works. Great!
> Martin
Current Time: Wed Nov 19 02:27:58 EST 2025
Powered by FUDForum. Page generated in 0.05561 seconds
