Home » Newcomers » Newcomers » workspace
workspace [message #97283] Thu, 25 August 2005 10:08 Go to next message
Originally posted by: aurphir.aurphir.com
Hi all
Greetings
I use network drive (from linux) in windows 2000 but I am not able to switch
my workspace in eclipse to this drive ........ its says workspace already in
use
any solutions??
Vishal Rana
Re: workspace [message #97329 is a reply to message #97283] Thu, 25 August 2005 10:33 Go to previous messageGo to next message
look if the .lock file is there. If it is and the workspace is not
really in use - delete the file and try again
If it is iin use and you delete the file - you'll be in trouble
/adam
Vishal Rana wrote:
> Hi all
> Greetings
> use
> any solutions??
> Regards
> Vishal Rana
Re: workspace [message #97372 is a reply to message #97329] Thu, 25 August 2005 10:43 Go to previous messageGo to next message
thanks but doesn't work
its always say workspace in use whenever I try to use network driver
"Adam Kiezun" <akiezun@mit.edu> wrote in message
news:dekkrk$vnm$1@news.eclipse.org...
> /adam
> Vishal Rana wrote:
> > Hi all
> > Greetings
switch
already in
> > use
> > any solutions??
> > Regards
> > Vishal Rana
Re: workspace [message #97387 is a reply to message #97283] Thu, 25 August 2005 10:43 Go to previous messageGo to next message
Originally posted by: eclipse3.rizzoweb.com
Vishal Rana wrote:
> Hi all
> Greetings
> use
> any solutions??
That means there is a .lock file in the workspace directory. Eclipse
creates this file whenever it is running, so it is most likely that
another instance of Eclipse is already running somewhere attached to
that workspace directory.
Also, note that Eclipse is not supported with a workspace on a non-local
drive. It might work, but chances are it will not perform well.
HTH,
Eric
Re: workspace [message #97400 is a reply to message #97329] Thu, 25 August 2005 11:05 Go to previous messageGo to next message
Hi Again I got it
Simply create a project and then right click create a new folder give a name
go to advanced option and link it to a file system i.e. you network drive
thanks for your support
> /adam
> Vishal Rana wrote:
> > Hi all
> > Greetings
switch
already in
> > use
> > any solutions??
> > Regards
> > Vishal Rana
Re: workspace [message #97813 is a reply to message #97283] Fri, 26 August 2005 10:36 Go to previous message
Originally posted by: john.eclipsefaq.org
See bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44735
The solution is to use this command line argument when launching Eclipse:
-Dosgi.locking=none
Vishal Rana wrote:
> Hi all
> Greetings
> use
> any solutions??
> Regards
> Vishal Rana
Previous Topic:get current projectname & workspacepath
Next Topic:Eclipse traning courseware?
Current Time: Wed Nov 05 18:02:30 EST 2025
Powered by FUDForum. Page generated in 0.09105 seconds
