| error IWAT0435E an error occured when connecting to the host [message #97170] |
Thu, 26 April 2007 12:55  |
Originally posted by: jrebreyend.amadeus.com
I have a problem getting eclipse retrieve the list of agents.
I have a weblogic server running, with option -XrunpiAgent:server=enabled .
The RA server is on and seems to be recognized by weblogic (if it is not on
when I start weblogic, an error message is displayed).
The problem happens when I want to profile the application from eclipse. I
go under profile>host, I create a new connection with the correct port. The
"test connection" feature returns true. But when I go to the "agents" tab to
select the agent, the task "fetching children of host" appears in eclipse,
and as soon as it is finished, instead of the list of agents, I got the
message "error IWAT0435E An error occured when connection to the host".
Did I forget one step? Does anyone can help?
I'm using versions agntctrl.win_ia32-TPTP-4.3.1 and
tptp.runtime-TPTP-4.3.1.zip with eclipse 3.2.0 and java 1.4.2.
Thanks in advance,
Julien
PS : I don't know if this could help to resolve the problem, but when I
decided to run SampleClient.exe to test RAServer, I got the result :
"Connected to the Agent Controller on "localhost" at port number 10006.
ERROR: Unable to get agent org.eclipse.tptp.TimeCollector". I read that some
other people had the problem but I didn't find a solution.
FUDForum. Page generated in 0.27887 seconds
