Reopening the workbench after it has been closed [message #97056] |
Sat, 05 July 2008 04:19  |
Originally posted by: s8424488.mail.inf.tu-dresden.de
we habe a RAP application which is displaying a login dialog in our
entrypoint before giving the user access to the workbench.
Now we would like to have the ability to get back to this login dialog
again, once the user closes the workbench, so that another user can login
from the same browser window.
Simply putting a loop around the code in the entry point obviously doesn't
seem to do the trick.
Is there any way to achieve this?
Philipp.
Re: Reopening the workbench after it has been closed [message #97462 is a reply to message #97189] |
Wed, 09 July 2008 17:53   |
Hi Rüdiger,
thank you for your response.
We have figured out the following workaround for our problem now:
After the workbench has been closed, we display a HTML-Page as described
in [1]. This HTML-Page just redirects the browser window to our
entrypoint. Quick, dirty, but does exactly what we need :-)
PlatformUI.createAndRunWorkbench(display, new WorbenchAdvisor());
// sorgt fuer den Reload, nachdem die Workbench geschlossen wurde:
Shell shell = new Shell(display, SWT.NONE);
shell.setMinimized(true);
Browser browser = new Browser(shell, SWT.NONE);
String page = "<html><body><script
type=\"text/JavaScript\">top.location.href=\""+url+"\"; </script></body></html>";
browser.setText(page);
shell.open();
Bye,
Philipp.
[1]
http://dev.eclipse.org/newslists/news.eclipse.technology.rap /msg02659.html
Rüdiger Herrmann wrote:
> Hi Philipp,
> this would mean to restart the workbench, which is currently not
> possible.
> Please see the threads "IWorkbench#restart behaves like
> IWorkbench#close" and "restart a workbench" for details.
> Cheers,
> Rüdiger
> Philipp wrote:
>> Hello,
>> login from the same browser window.
>> doesn't seem to do the trick.
>> Best regards,
>> Philipp.
Re: Reopening the workbench after it has been closed [message #97484 is a reply to message #97462] |
Thu, 10 July 2008 04:13  |
Hi Philipp,
If you get into trouble with session timeouts consider the following
alternative for redirection:
String page = "<html><head><title>Session timed out</title>"
+ "<meta http-equiv=\"refresh\" content=\"3; url=" + entryUrl + "\">"
+ "</head><body><p>User logged out.<br>"
+ "Redirecting to login page in 3 seconds..."
+ "<p>If you are experiencing problems with the redirection please use "
+ "<a href=" + entryUrl + ">this direct link</a>."
+ "</body></html>";
That was necessary in our project because the user was redirected to the
login page while the session wasn't timed out completely (the parameter
for setMaxInactiveInterval can't be less than 1).
Bye - Reinhold.
FUDForum. Page generated in 0.06286 seconds
