Home » Language IDEs » PHP Development Tools (PDT) » [Announce] PDT 2.0.1 is available
[Announce] PDT 2.0.1 is available [message #96819] Fri, 01 May 2009 03:46 Go to next message
Originally posted by: pdtBuild.build.eclipse.org
The following build [1] will be available at eclipse.org in the next 30-60 mins.
[1] http://www.eclipse.org/pdt/downloads/?project=pdt&showAl l=1&hlbuild=R200904281148#R200904281148
Updated release notes [2] should be updated within 24hrs.
[2] http://www.eclipse.org/pdt/news/relnotes.php?project=pdt& ;version=2.0.1
Re: [Announce] PDT 2.0.1 is available [message #96834 is a reply to message #96819] Sat, 02 May 2009 13:34 Go to previous messageGo to next message
If you look at http://download.eclipse.org/tools/pdt/updates/2.0/ you
see that the version of the features have version 2.0.0.v20090315-1850,
although it advertises itself as PDT SDK 2.0.1.
I think this is incorrect. Eclipse says that there is nothing to update,
while my current install is 2.0.0.
Re: [Announce] PDT 2.0.1 is available [message #96999 is a reply to message #96834] Wed, 06 May 2009 00:52 Go to previous messageGo to next message
Anyone? The downloads are all version 2.0.0.v20090315-1850. Is this 2.0.1?
Re: [Announce] PDT 2.0.1 is available [message #97081 is a reply to message #96834] Fri, 08 May 2009 06:00 Go to previous messageGo to next message
*kick*
Is there any new folks?
Re: [Announce] PDT 2.0.1 is available [message #97158 is a reply to message #96834] Mon, 11 May 2009 16:56 Go to previous messageGo to next message
*kick #2*
The current primary download all-in-one is 2.0.1.
Still, the update site shows only code from 2.0.0 (code from march).
Could the devs please fix the update site, or indicate that these
versions are equivalent?
Re: [Announce] PDT 2.0.1 is available [message #97234 is a reply to message #97158] Tue, 12 May 2009 09:17 Go to previous messageGo to next message
in the update I see that 2.0.1 is declared, but with the wrong suffix
(instead of 2.0.1 there is 2.0.0:
<!-- PDT 2.0.1 -->
<category-def label="PDT SDK 2.0.1" name="PDT SDK 2.0.1">
<description>
PDT SDK 2.0.1: contains runtime, source, and documentation.
</description>
</category-def>
<feature id="org.eclipse.php.sdk" version="2.0.0.v20090315-1850"
url="features/org.eclipse.php.sdk_2.0.0.v20090315-1850.jar" patch="false">
<category name="PDT SDK 2.0.1"/>
</feature>
<feature id="org.eclipse.php" version="2.0.0.v20090315-1850"
url="features/org.eclipse.php_2.0.0.v20090315-1850.jar" patch="false">
</feature>
<feature id="org.eclipse.php.source" version="2.0.0.v20090315-1850"
url="features/org.eclipse.php.source_2.0.0.v20090315-1850.jar "
patch="false">
</feature>
Can you create an issue about it and so we'll be able to track this.
- Roy
Re: [Announce] PDT 2.0.1 is available [message #97264 is a reply to message #97234] Tue, 12 May 2009 13:04 Go to previous message
Thanks for responding: Here you go:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=275914
[Since pdt 2.0.0 refused to give code completion anymore I've already
downloaded pdt 2.0.1 all-in-one and recreated everything.]
Previous Topic:method completion
Next Topic:PDT for the Visual Editor
Current Time: Wed Nov 12 04:05:27 EST 2025
Powered by FUDForum. Page generated in 0.05011 seconds
