Home » Language IDEs » Java Development Tools (JDT) » code formatter problem
code formatter problem [message #96730] Thu, 18 September 2003 04:03 Go to next message
i have a small problem with the code formatter. Unter
Window->Preferences->Java->Code Formatter it
is possible to change the way the code is formatted. However it is not
possible to tell eclipse to
insert a space between the method name / class name and the following
opening bracket :
e.g :
StringBuffer sb = new StringBuffer();
sb.toString();
however i want the code to look like :
StringBuffer sb = new StringBuffer ();
sb.toString (); ^
^ a space character
a space character
did i miss something, or is it not possible to tell eclipse to insert a
space character ?
thanks in advance,
Andreas
Re: code formatter problem [message #96748 is a reply to message #96730] Thu, 18 September 2003 04:55 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Andreas,
this is currently not possible. Feel free to file a feature request
against JDT Core.
Dani
Andreas Wuest wrote:
>Hi,
>opening bracket :
>e.g :
>sb.toString();
>sb.toString (); ^
> ^ a space character
> a space character
>space character ?
>thanks in advance,
> Andreas
Re: code formatter problem [message #96761 is a reply to message #96730] Thu, 18 September 2003 05:22 Go to previous messageGo to next message
Originally posted by: wagner.stefan.berlin.de
Hi Andreas,
> opening bracket :
> sb.toString();
> sb.toString ();
I prefer this Layout too.
It is the standard for Textlayout in Bookprinting to have blanks OUT of the
braces, and no blank inside,
e.g.
aaa.doIt (a, b, c);
aaa.doIt (a, b);
aaa.doIt ();
and bookprinting is taking place since about 400 years, so they have a lot
of experience.
It is much better readable, especially in the 'outline'-window.
Re: code formatter problem [message #96776 is a reply to message #96761] Thu, 18 September 2003 07:40 Go to previous message
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Thu, 18 Sep 2003 11:22:28 +0200, "Stefan Wagner"
>e.g.
>aaa.doIt (a, b, c);
>aaa.doIt (a, b);
>aaa.doIt ();
This will be possible with the new formatter.
Olivier
Previous Topic:Using "Ant" from within eclipse...
Next Topic:Getting source file for IPackageFragmentRoot
Current Time: Sat Nov 15 01:01:35 EST 2025
Powered by FUDForum. Page generated in 0.06767 seconds
