Home » Language IDEs » Java Development Tools (JDT) » Eclipse debug problem
Eclipse debug problem [message #96594] Wed, 17 September 2003 10:52 Go to next message
Originally posted by: stephen.gair.reflective.com
Hi - I find that when I am debugging code using the Eclipse 2.1.1
remote debugger (WLS 6.1, jdk131) - I am unable to inspect local
variables. Does anyone one have any idea why this might be? (I am able
to see class variables).
Thanks for your help, Stephen.
Re: Eclipse debug problem [message #96825 is a reply to message #96594] Thu, 18 September 2003 10:11 Go to previous messageGo to next message
Local variables (and args) are only available if the class you are debugging
was compiled with the appropriate debug information. Generally, class
libraries do not have this information. You can control what debug
attributes are placed in your class files via the compiler options in
Eclipse.
Darin
"Stephen Gair" <stephen.gair@reflective.com> wrote in message
news:bk9sfd$67p$1@eclipse.org...
Re: Eclipse debug problem [message #112205 is a reply to message #96825] Thu, 30 October 2003 18:57 Go to previous message
Originally posted by: mapsljh68.hotmail.com
Hi Darin,
Sometimes when I traced into a mothed, I can view one of its arguments but
not the other, or I can inpect some of its local variables but not the
others. Is this caused by the same reason?
I think if you can trace into some source code, you should be allowed to
view the variables/args in those source code. It's frustrating when you step
on a line but cannot inspect a variable of interest on that line.
Is there a debug build sdk library that has enough debug information for
viewing variables?
Thanks, Bull
"Darin Wright" <Darin_Wright@ca.ibm.com> wrote in message
news:bkcecl$i7s$1@eclipse.org...
debugging
> Eclipse.
> Darin
Previous Topic:Migration to WSAD IE
Next Topic:How to change to use SUN JAVAC compiler
Current Time: Sun Nov 30 01:38:06 EST 2025
Powered by FUDForum. Page generated in 0.03782 seconds
