Home » Archived » BIRT » disable schema browsing for large DBs?
disable schema browsing for large DBs? [message #96552] Mon, 05 December 2005 07:30 Go to next message
Originally posted by: aschelleckes.de.pepperl-fuchs.com
hi there,
i am looking for a way to disable the schema browsing feature within
dataset builder. we are using a very large DB2 database with many
libraries (schemas) and even more tables. loading the dataset builder tool
takes more than 3 minutes every time you open it because it loads every
schema and table.
is there any way to disable browsing or to restrict browsing to only some
schemas, or to cache once downloaded schema/table information?
thanks for your comments,
achim
Re: disable schema browsing for large DBs? [message #96650 is a reply to message #96552] Mon, 05 December 2005 14:03 Go to previous message
achim wrote:
> hi there,
Hello achim;
We had the same situation and filed a bugzilla entry. It looks like they
have addressed this issue in the upcoming release (see below):
https://bugs.eclipse.org/bugs/show_bug.cgi?id=115671
------- Additional Comments From lzhu@actuate.com 2005-11-17 02:35
------- We have added a preference page to birt which can limit the number
of schemas being fetched once sql dataset editor is open. If the number is
set to 0 then no schema will be fetch when the editor is open.By default
the number of schema to be fetched is 20.
Hope this answers your question.
Pete H
Previous Topic:Replacing text in a cell
Next Topic:BIRT Demo (download)
Current Time: Sun Nov 02 06:56:18 EST 2025
Powered by FUDForum. Page generated in 0.45362 seconds
