Home » Eclipse Projects » Eclipse Platform » How to trap the Save Event?
How to trap the Save Event? [message #96392] Fri, 18 July 2003 07:49 Go to next message
I would like to add some functionality to my java class when i try to save
the file. In order to do that i need to trap the save event of Eclipse
IDE. I tried to use a class extending org.eclipse.ui.internal.SaveAction
and in the run method i try to perform some action. Then i try to set the
gloabalActionHandler as my class. Even on doing this i dont get my action
being fired.
Plz provide good suggestions to me.
cheers
Easwar
Re: How to trap the Save Event? [message #96915 is a reply to message #96392] Fri, 18 July 2003 17:53 Go to previous message
Easwar wrote:
> being fired.
Is your "java class" an Editor? If so, you can just override the doSave
method.
Apologies if that isn't your situation.
Andy
Previous Topic:Hooks into the Synchronize View Context Menu
Next Topic:how to save merged changes in CompareUI class
Current Time: Fri Nov 07 08:32:55 EST 2025
Powered by FUDForum. Page generated in 0.03404 seconds
