Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » JET EXTENSION!
JET EXTENSION! [message #95902] Wed, 05 September 2007 12:32 Go to next message
Originally posted by: fhenus.hotmail.com
Hello guys, i
Re: JET EXTENSION! [message #95917 is a reply to message #95902] Wed, 05 September 2007 12:57 Go to previous messageGo to next message
Rafael,
I'll redirect your question to the M2T newsgroup which I've added to the
"to" list of my reply (so there's no need to repost the question).
Rafael Ribeiro wrote:
> Hello guys, i´ve trying to find material about JET Extension Points but its
> being really hard to find it. Got me questioning if anyone its using this
> wonderful feature. :D
> What i have to ask its this. I know that the JET engine translates text
> templates to a Java class that generates the real output.
> What i want to know its that there is a way to extend the code that the JET
> engine generates. Putting things simple, i want to put a tag in a template
> that will generate some code on the Java class. EX: A tag like
> <custom:Property name="FolderPath" type="String"> and when the JET compiles
> the template the JAVA class will have a attribute FolderPath, and with
> getter and setters.
> Until now i just found custom tags that transform the resulting
> transformation, not the java class itself. Can this be done?
> Thanks anyway, cya.
Re: JET EXTENSION! [message #95932 is a reply to message #95917] Wed, 05 September 2007 13:30 Go to previous messageGo to next message
Being diging around, and i saw some people asking abount custom directives.
Does the JET engine already support this?
I
Re: JET EXTENSION! [message #95958 is a reply to message #95932] Thu, 06 September 2007 08:13 Go to previous messageGo to next message
Rafael:
JET permits you to define "custom tags" (XML tags that are interpreted by
the engine at runtime). You can get some details from the JET FAQ:
"Rafael Ribeiro" <fhenus@hotmail.com> wrote in message
news:fbmp4e$i9p$1@build.eclipse.org...
> directives. Does the JET engine already support this?
> I
Re: JET EXTENSION! [message #95973 is a reply to message #95958] Thu, 06 September 2007 08:16 Go to previous messageGo to next message
Hmm... lets try that again..
Rafael:
http://wiki.eclipse.org/JET_FAQ_How_do_I_create_custom_tag%3 F
JET does not permit you to defined custom directives <%@xxx %>, which are
interpreted by the JET compiler at compile time. But, so far, custom tags
have been all that anyone has needed.
Also, before you embark on creating custom tags, take a look at the supplied
library.
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. jet.doc/references/taglibs/index.xhtml
Paul
Re: JET EXTENSION! [message #96093 is a reply to message #95973] Thu, 06 September 2007 10:17 Go to previous messageGo to next message
Hello Paul,
Hehehe i
Re: JET EXTENSION! [message #96109 is a reply to message #96093] Thu, 06 September 2007 11:14 Go to previous messageGo to next message
Rafael:
Keep me posted on your progress. Maybe this is something you can contribute
back to the community!
Paul
news:fbp259$8lv$1@build.eclipse.org...
> Hello Paul,
> Hehehe i
Re: JET EXTENSION! [message #96285 is a reply to message #96109] Fri, 07 September 2007 10:05 Go to previous messageGo to next message
Hi Paul, i just finished the implementation. The problem now its to run the
JET compilation without building a plugin. As i now JET only runs on top of
eclipse or on a headless eclipse. Is there another way to run only the
compilation?
I want to do a simple unit test to my code that just receives the template
path, or stream, compile it and get the result. Could you help me with that?
PS: Sorry if this are really newbie questions... its that i
Re: JET EXTENSION! [message #96346 is a reply to message #96285] Fri, 07 September 2007 12:33 Go to previous message
Never mind, i
Re: JET EXTENSION! [message #609645 is a reply to message #95902] Wed, 05 September 2007 12:57 Go to previous message
Rafael,
> getter and setters.
> Thanks anyway, cya.
Re: JET EXTENSION! [message #609646 is a reply to message #95917] Wed, 05 September 2007 13:30 Go to previous message
I
Re: JET EXTENSION! [message #609648 is a reply to message #95932] Thu, 06 September 2007 08:13 Go to previous message
Rafael:
> I
Re: JET EXTENSION! [message #609649 is a reply to message #95958] Thu, 06 September 2007 08:16 Go to previous message
Rafael:
library.
Paul
Re: JET EXTENSION! [message #609652 is a reply to message #95973] Thu, 06 September 2007 10:17 Go to previous message
Hello Paul,
Hehehe i
Re: JET EXTENSION! [message #609653 is a reply to message #96093] Thu, 06 September 2007 11:14 Go to previous message
Rafael:
Paul
> Hello Paul,
> Hehehe i
Re: JET EXTENSION! [message #609664 is a reply to message #96109] Fri, 07 September 2007 10:05 Go to previous message
compilation?
Re: JET EXTENSION! [message #609675 is a reply to message #96285] Fri, 07 September 2007 12:33 Go to previous message
Never mind, i
Previous Topic:[CDO][0.8.0] Streaming
Next Topic:[CDO][0.8.0] Update
Current Time: Thu Nov 06 23:51:47 EST 2025
Powered by FUDForum. Page generated in 0.05701 seconds
