Home » Eclipse Projects » Equinox » Problem with Tomcat looping when using BridgeServlet with the console option on
Problem with Tomcat looping when using BridgeServlet with the console option on [message #95634] Wed, 22 August 2007 04:29 Go to next message
When I have the console option turned on:
<web-app id="WebApp">
<servlet id="bridge">
<servlet-name>equinoxbridgeservlet</servlet-name>
<display-name>Equinox Bridge Servlet</display-name>
<description>Equinox Bridge Servlet</description>
<servlet-class>org.eclipse.equinox.servletbridge.BridgeServlet </servlet-class>
<init-param>
<param-name>commandline</param-name>
<param-value>-console</param-value>
</init-param>
My Tomcat (6.0.14) goes into a loop taking all CPU, outputing this to
the log:
Aug 22, 2007 1:24:58 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The Apache Tomcat Native library which allows optimal performance
in production environments was not found on the java.library.path:
/usr/java/jdk1.6.0/jre/lib/i386/server:/usr/java/jdk1.6.0/jr e/lib/i386:/usr/java/jdk1.6.0/jre/../lib/i386:/usr/java/j2sd k1.4.2_13/bin/classic:/usr/java/j2sdk1.4.2_13/jre/bin::/usr/ java/packages/lib/i386:/lib:/usr/lib
Aug 22, 2007 1:24:58 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Aug 22, 2007 1:24:58 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 786 ms
Aug 22, 2007 1:24:58 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Aug 22, 2007 1:24:58 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.14
Aug 22, 2007 1:24:58 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive osdm.war
osgi>
osgi>
osgi>
(these go on forever, and in my emacs it shows as a ^M after each osgi>
prompt)
Any ideas?
Re: Problem with Tomcat looping when using BridgeServlet with the console option on [message #95650 is a reply to message #95634] Wed, 22 August 2007 10:17 Go to previous messageGo to next message
Hi Francis,
A similar problem was reported by Roberto Sanchez on June 1 "Critical
Problem with osgi console".
We're not currently able to reproduce the problem and are unsure as to what
is the cause.
Any info you can add would help --
https://bugs.eclipse.org/bugs/show_bug.cgi?id=192361
-Simon
"Francis Upton" <francisu@ieee.org> wrote in message
news:fags4s$64k$1@build.eclipse.org...
> <init-param>
> <param-value>-console</param-value> </init-param>
> My Tomcat (6.0.14) goes into a loop taking all CPU, outputing this to the
> log:
> INFO: The Apache Tomcat Native library which allows optimal performance in
> osgi>
> osgi>
> osgi>
> prompt)
> Any ideas?
Re: Problem with Tomcat looping when using BridgeServlet with the console option on [message #95693 is a reply to message #95650] Wed, 22 August 2007 12:57 Go to previous message
Thanks Simon, I updated the bug report providing what you need to
reproduce it.
I'm not good at being able to debug an instance of Tomcat in the Eclipse
debugger and get at the code for the Eclipse code that is started by
the servlet bridge (I'm not even sure this is possible, and I have
tried). If this was possible and you could show me the way, I would
be happy to debug this myself.
Francis
Simon Kaegi wrote:
> Hi Francis,
> is the cause.
> -Simon
>> <init-param>
>> log:
>> osgi>
>> osgi>
>> osgi>
>> prompt)
>> Any ideas?
Previous Topic:Using Class.forName or Bundle.loadClass in bundles - whats the difference?
Next Topic:Deploy WAR unexploded into Equinox
Current Time: Sat Jul 26 09:30:29 EDT 2025
Powered by FUDForum. Page generated in 0.25370 seconds
