Problems in creating a J2EE web application [message #95484] |
Wed, 27 April 2005 11:15  |
Originally posted by: Rao.Pankaj.gmail.com
Hi All,
I am using Eclispe 3.1 M6 release with The Eclipse Web Tools Platform
(WTP) plugin. I have j2re1.4.2_07 and jakarta-tomcat-4.1.30 installed on
my machine. When I try to create a new J2EE Web Project I get following
exception in my log file. Any help to resolve this problem would be highly
appreciated.
Saint007
!ENTRY org.eclipse.ui 4 4 2005-04-27 16:35:40.219
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-04-27 16:35:40.229
!MESSAGE
org.eclipse.ui.internal.WorkbenchMessages.getString(Ljava/la ng/String;)Ljava/lang/String;
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jst.j2ee.internal.wizard.J2EEModulesDependencyPa ge.createTopLevelComposite(J2EEModulesDependencyPage.java:92 )
org.eclipse.wst.common.frameworks.ui.WTPWizardPage.createCon trol(WTPWizardPage.java:99)
org.eclipse.wst.common.frameworks.ui.ExtendableWizard.create PageControls(ExtendableWizard.java:146)
org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:611)
at org.eclipse.jface.wizard.WizardDialog.setWizard(WizardDialog .java:965)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1016)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
at org.eclipse.ui.actions.NewProjectAction.run(NewProjectAction .java:114)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
FUDForum. Page generated in 0.06975 seconds
