| Usage of Figure#revalidate and Figure#repaint [message #8613] |
Fri, 07 June 2002 09:02  |
Originally posted by: g.wagenknecht.intershop.de
Hi!
I have created the following figure.
public class MyFigure extends Figure
private Label myLabel;
// MyCompositeImageDescriptor inherits from
// org.eclipse.jface.resource.CompositeImageDescriptor
private MyCompositeImageDescriptor myCompositeImageDescriptor;
public MyFigure( ImageDescriptor image )
super();
setLayoutManager(new StackLayout());
myCompositeImageDescriptor = new MyCompositeImageDescriptor(image);
myLabel = new Label( myCompositeImageDescriptor.createImage() );
add(myLabel);
protected void setBaseImage( ImageDescriptor image )
myCompositeImageDescriptor.setBaseImage( image );
Now, if I call #setBaseImage the new image is set, but not shown. (Maybe
this
a bug, but I think this happens because of design.)
I have to tell myLabel to use the new image. For that I must call
"myLabel.setIcon(myCompositeImageDescriptor.createImage())".
If I do this in #setBaseImage, everything is fine. But I want a more generic
solution because I don't want inherited figures to do this manually.
Is there a better way of doing this? Should I
overwrite repaint() or revalidate() method of the figure?
Cu, Gunnar
| Re: Usage of Figure#revalidate and Figure#repaint [message #8624 is a reply to message #8613] |
Fri, 07 June 2002 09:35   |
Originally posted by: none.ibm.com
Calling myCompositeImageDescriptor.setBaseImage() does *NOT* update the
Image that was returned by compDesc.createImage(). Unless you've done
something in your subclass.
CompositeImageDescriptor is a workaround for the fact that SWT Tree/Table
can only have a single Icon. It has limitations. For example, if you have
1 base Image and 8 different decorators, this leads to 256 Images, which
takes up 256 OS resource handles. In draw2d you could acheive the same
thing by calling graphics.drawImage() a few times with the various
decorators. IMO, there is no motivation to compose the Image.
What are you trying to create? An Icon with a few decorations or ports on
it?
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:adq9ov$f13$1@rogue.oti.com...
> Hi!
> super();
> add(myLabel);
> this
generic
> Cu, Gunnar
| Re: Usage of Figure#revalidate and Figure#repaint [message #8712 is a reply to message #8701] |
Sat, 08 June 2002 23:49  |
> > You should not that this is porbably a memory *LEAK*. I believe
composite
> > ImageDescriptor will hold onto the original composed Image from the
> previous
> > time you called setBaseImage(). So, every time you change the base you
> will
> > be leaking one Image
> So what do you suggest?? You mentiond I could draw the images myself
> (graphics#drawImage). Where do I have do this? I'm not sure.
Actually, ComposedImageDescriptor doesn't cache Images because Descriptors
by definition don't manage an Image. So, when you change the base image
*you* have to dispose the old one. It's your Image at that point, so there
should be no leak.
The caches I was thinking of are in ActionContributionItem and some
Decorator class.
FUDForum. Page generated in 0.03799 seconds
