| Available widgets for use in RAP [message #95343] |
Tue, 01 July 2008 02:25  |
Originally posted by: sarek.nurfuerspam.de
Hi all,
I am relatively new to RAP and I am planning to do my current project as
RAP application. However I am a bit confused about what widgets are
actually available in RAP as compared to standard SWT widgets (i have
only done 'plain SWT applications' before).
Is there any comprehensive listing which widgets are available right
now, maybe which will be supported in the near future and which won't be
available at all?
Thanks in advance for your help.
Christian
To reply to this posting directly use the following address and
remove the 'NO-SPAM' part: Riedel.Christian.NO-SPAM@gmx.net
| Re: Available widgets for use in RAP [message #95578 is a reply to message #95533] |
Tue, 01 July 2008 13:21  |
Thanks, Rüdiger!
I think I will simply start developing, give it a try and see where I
get stuck ;-)
I will have a look at your link. It's a starting point at least.
Bye
Christian
Rüdiger Herrmann schrieb:
> Christian,
> we currently don't have such a listing that is up-to-date.
> You could take a look at the call hierarchy of Widget to get an overview
> which widgets are missing.
> In addition, the list of enhancement requests [1] lists some widgets and
> methods that are yet missing.
> In the near future there will be ExpandBar, DateTime and Scale widgets
> available. The respective enhancement requests are also listed here: [1]
> In case you intend to port an existing RCP or SWT application to RAP, I
> would recommend to compile the existing code against a RAP target.
> RAP/RWT does not implement empty API, therefore you can go along the
> compile errors to get an overview of what is missing for your specific
> needs.
> Cheers,
> Rüdiger
> [1]
> https://bugs.eclipse.org/bugs/buglist.cgi?query_format=advan ced&short_desc_type=allwordssubstr&short_desc=&p roduct=RAP&long_desc_type=allwordssubstr&long_desc=& amp;bug_file_loc_type=allwordssubstr&bug_file_loc=&s tatus_whiteboard_type=allwordssubstr&status_whiteboard=& amp;keywords_type=allwords&keywords=&bug_status=NEW& amp;bug_status=ASSIGNED&bug_status=REOPENED&bug_seve rity=enhancement&emailtype1=substring&email1=&em ailtype2=substring&email2=&bugidtype=include&bug _id=&votes=&chfieldfrom=&chfieldto=Now&chfie ldvalue=&cmdtype=doit&order=Reuse+same+sort+as+last+ time&field0-0-0=noop&type0-0-0=noop&value0-0-0=
> Christian Riedel wrote:
>> Hi all,
>> as RAP application. However I am a bit confused about what widgets are
>> be available at all?
>> Christian
FUDForum. Page generated in 0.03614 seconds
