| Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Teneo/Hibernate Column Annotation Column
 Goto Forum:|
| Teneo/Hibernate Column Annotation Column [message #95247] | Sat, 01 September 2007 04:00  |  |
| Eclipse User  |  |  |  |  | Hi,
 I am trying to use the column annotation to change the length. The attribute
 datatype is EString and the Class that has this attribute is in a
 sub-package. I tried the model annotation. Through the generated code has
 the annotation it is not getting picked up. The column length remains the
 same. I also tries to use the JPA annotation directly on the getter method
 for that attribute. This also has no effect.
 Here is the details of methods that I have tried.
 1. Model Annotation:
 Source : http://annotation.elver.org/Column
 Key: length
 Value: 500
 In the generated code I see this:
 * Returns the value of the '<em><b>Value</b></em>' attribute.
 * <!-- begin-user-doc -->
 * <p>
 * If the meaning of the '<em>Value</em>' attribute isn't clear,
 * there really should be more of a description here...
 * </p>
 * <!-- end-user-doc -->
 * @return the value of the '<em>Value</em>' attribute.
 * @see #setValue(String)
 * @see
 org.eclipse.hyades.models.common.interactions.Common_Behavio r_InteractionsPackage#getBVRArgument_Value()
 * @model annotation="http://annotation.elver.org/Column length='500'"
 * @generated
 String getValue();
 2. JPA annotation
 * <p>
 * </p>
 * @see
 @Column(length=500)
 String getValue();
 Both of these methods fail to change the column length. Please help me in
 resolving this issue.
 Phaneesh
| Re: Teneo/Hibernate Column Annotation Column [message #95423 is a reply to message #95247] | Sun, 02 September 2007 06:01   |  |
| Eclipse User  |  |  |  |  | Hi Phaneesh, The first method you tried did not follow the format (source should be teneo.jpa, key should be
 value) as described here:
 http://www.elver.org/hibernate/ejb3_format.html
 Your second method won't work with Teneo, tou have to set the annotation in the ecore model (or xsd)
 or in a separate xml file (see also the link noted above).
 gr. Martin
 Phaneesh wrote:
 > Key: length
 > Value: 500
 >   * <p>
 >   * </p>
 >   * @see
 >   * @generated
 >  String getValue();
 > 2. JPA annotation
 >   * <p>
 >   * </p>
 >   * @see
 > @Column(length=500)
 >  String getValue();
 > Regards
 > Phaneesh
 With Regards, Martin Taal
 Springsite/Elver.org
 The Netherlands
 Tel: +31 (0)84 420 2397
 Fax: +31 (0)84 225 9307
| Re: Teneo/Hibernate Column Annotation Column [message #95576 is a reply to message #95423] | Sun, 02 September 2007 23:34   |  |
| Eclipse User  |  |  |  |  | Hi Martin,
 I tried source=teneo.jpa and value=@Column(length=500) and source=teneo.jpa
 appinfo=@Column(length=500) both these have no effect on the teneo created
 hibernate mapping file. It does not put the length attribute to the target
 column.
 The generated model code in both cases:
 1. Source=teneo.jpa and value=@Column(length=500)
 * <p>
 * </p>
 * @see
 * @model annotation="teneo.jpa value='@Column(length=500)'"
 * @generated
 String getValue();
 2. Source=teneo.jpa and appinfo=@Column(length=500)
 * <p>
 * </p>
 * @see
 * @model annotation="teneo.jpa appinfo='@Column(length=500)'"
 * @generated
 String getValue();
 Here is the generated mapping file for the same:
 <property name="value" lazy="false" insert="true" update="true"
 not-null="false" unique="false" type="java.lang.String">
 <column not-null="false" unique="false" name="`VALUE`"/>
 </property>
 Please tell me if I am missing something.
 Phaneesh
 "Martin Taal" <mtaal@elver.org> wrote in message
 news:fbe1m9$a8q$1@build.eclipse.org...
 > Hi Phaneesh,
 > teneo.jpa, key should be value) as described here:
 > in the ecore model (or xsd) or in a separate xml file (see also the link
 > noted above).
 > gr. Martin
 > Phaneesh wrote:
 >> attribute datatype is EString and the Class that has this attribute is in
 >> a sub-package. I tried the model annotation. Through the generated code
 >> has the annotation it is not getting picked up. The column length remains
 >> the same. I also tries to use the JPA annotation directly on the getter
 >> method for that attribute. This also has no effect.
 >> Key: length
 >> Value: 500
 >>   * <p>
 >>   * </p>
 >>   * @see
 >>   * @generated
 >>  String getValue();
 >> 2. JPA annotation
 >>   * <p>
 >>   * </p>
 >>   * @see
 >> @Column(length=500)
 >>  String getValue();
 >> Regards
 >> Phaneesh
 > The Netherlands
| Re: Teneo/Hibernate Column Annotation Column [message #95617 is a reply to message #95576] | Mon, 03 September 2007 05:17   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------070501080601070404000102
 Hi Phaneesh,
 I have attached the ecore file which is used (in Teneo) as a testcase for the column annotation.
 This works for Teneo. Can you check if you have specified the annotation in the same way (in the
 ecore file or xsd)?
 gr. Martin
 Phaneesh wrote:
 > Hi Martin,
 > column.
 >   * <p>
 >   * </p>
 >   * @see
 >   * @generated
 >  String getValue();
 >   * <p>
 >   * </p>
 >   * @see
 >   * @generated
 >  String getValue();
 >   </property>
 > Regards
 > Phaneesh
 >> Hi Phaneesh,
 >> noted above).
 >> gr. Martin
 >> Phaneesh wrote:
 >>> Hi,
 >>> Key: length
 >>> Value: 500
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>>   * @generated
 >>>  String getValue();
 >>> 2. JPA annotation
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>> @Column(length=500)
 >>>  String getValue();
 >>> Regards
 >>> Phaneesh
 >> The Netherlands
 The Netherlands
 Content-Type: text/xml;
 name="column.ecore"
 Content-Disposition: inline;
 filename="column.ecore"
 <ecore:EPackage xmi:version="2.0"
 xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
 xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="column"
 nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/col umn" nsPrefix="column">
 <eClassifiers xsi:type="ecore:EClass" name="Book">
 <eAnnotations source="teneo.jpa">
 <details key="appinfo" value="@Table(name="mybooktable")"/>
 </eAnnotations>
 <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
 <details key="name" value="Book"/>
 <details key="kind" value="elementOnly"/>
 </eAnnotations>
 <eStructuralFeatures xsi:type="ecore:EAttribute" name="title" unique="false" lowerBound="1"
 eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
 <details key="appinfo" value="@Column(name="titel" unique="true" length="25")"/>
 </eAnnotations>
 <details key="kind" value="element"/>
 <details key="name" value="title"/>
 </eAnnotations>
 </eStructuralFeatures>
 <eStructuralFeatures xsi:type="ecore:EAttribute" name="pages" unique="false" lowerBound="1"
 eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Int" unsettable="true">
 <details key="appinfo" value="@Column(updatable="false" insertable="false")"/>
 </eAnnotations>
 <details key="name" value="pages"/>
 </eAnnotations>
 <eStructuralFeatures xsi:type="ecore:EAttribute" name="weight" unique="false"
 lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Decimal">
 <details key="appinfo" value="@Column(name="gewicht" nullable="true" precision="5" scale="2")"/>
 </eAnnotations>
 <details key="name" value="weight"/>
 </eAnnotations>
 <eStructuralFeatures xsi:type="ecore:EAttribute" name="author" unique="false"
 lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
 <details key="name" value="author"/>
 </eAnnotations>
 </eClassifiers>
 </ecore:EPackage>
 --------------070501080601070404000102--
| Re: Teneo/Hibernate Column Annotation Column [message #95747 is a reply to message #95617] | Mon, 03 September 2007 10:46   |  |
 Thanks for the update. I was using a single quote in the annotation.
 Instead of @Column(length=500) I was using @Column(length='500').
 Now it is working!!. The hibernate mapping file has the length attribute set
 to the target column. But, the problem now is the schema is not getting
 updated.
 I have hibernate.hbm2ddl.auto = update in hbernate configuration, and in
 teneo config I have set teneo.runtime.update_schema=true. But the table is
 not getting updated in the database. I am using oracle 10 database. If I
 change the hibernate.hbm2ddl.auto to create and then run it on a new schema
 the column length is set to the desired value. May be there is a sync issue.
 Please tell me whether I have set any other option in teneo?
 Phaneesh
 news:fbgjf0$snn$1@build.eclipse.org...
 > Hi Phaneesh,
 > ecore file or xsd)?
 > gr. Martin
 > Phaneesh wrote:
 >> Hi Martin,
 >> source=teneo.jpa
 >> created
 >> target
 >> column.
 >>   * <p>
 >>   * </p>
 >>   * @see
 >>   * @generated
 >>  String getValue();
 >>   * <p>
 >>   * </p>
 >>   * @see
 >>   * @generated
 >>  String getValue();
 >>   </property>
 >> Regards
 >> Phaneesh
 >>> Hi Phaneesh,
 >>> noted above).
 >>> gr. Martin
 >>> Phaneesh wrote:
 >>>> Hi,
 >>>> in
 >>>> remains
 >>>> Key: length
 >>>> Value: 500
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>>   * @generated
 >>>>  String getValue();
 >>>> 2. JPA annotation
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>> @Column(length=500)
 >>>>  String getValue();
 >>>> in
 >>>> Regards
 >>>> Phaneesh
 >>> The Netherlands
 > The Netherlands
 > nsPrefix="column">
 >    </eAnnotations>
 >    <eAnnotations
 >    </eAnnotations>
 >      </eAnnotations>
 >      <eAnnotations
 >      </eAnnotations>
 >      </eAnnotations>
 >      <eAnnotations
 >      </eAnnotations>
 > unique="false"
 >      </eAnnotations>
 >      <eAnnotations
 >      </eAnnotations>
 > unique="false"
 >      <eAnnotations
 >      </eAnnotations>
 >  </eClassifiers>
 > </ecore:EPackage>
| Re: Teneo/Hibernate Column Annotation Column [message #95781 is a reply to message #95747] | Mon, 03 September 2007 13:48   |  |
| Eclipse User  |  |  |  |  | Hi Phaneesh I don't think that this has to do with Teneo but more with how hibernate updates the schema. For
 example my experience is that new indexes are also only added in a create mode. So it seems to be a
 hibernate 'feature'.
 gr. Martin
 Phaneesh wrote:
 > Hi Martin,
 > updated.
 > Regards
 > Phaneesh
 >> Hi Phaneesh,
 >> ecore file or xsd)?
 >> gr. Martin
 >> Phaneesh wrote:
 >>> Hi Martin,
 >>> source=teneo.jpa
 >>> created
 >>> target
 >>> column.
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>>   * @generated
 >>>  String getValue();
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>>   * @generated
 >>>  String getValue();
 >>>   </property>
 >>> Regards
 >>> Phaneesh
 >>>> Hi Phaneesh,
 >>>> noted above).
 >>>> gr. Martin
 >>>> Phaneesh wrote:
 >>>>> Hi,
 >>>>> in
 >>>>> remains
 >>>>> Key: length
 >>>>> Value: 500
 >>>>>   * <p>
 >>>>>   * </p>
 >>>>>   * @see
 >>>>>   * @generated
 >>>>>  String getValue();
 >>>>> 2. JPA annotation
 >>>>>   * <p>
 >>>>>   * </p>
 >>>>>   * @see
 >>>>> @Column(length=500)
 >>>>>  String getValue();
 >>>>> in
 >>>>> Regards
 >>>>> Phaneesh
 >>>> The Netherlands
 >> The Netherlands
 >> <?xml version="1.0" encoding="UTF-8"?>
 >> nsPrefix="column">
 >>    </eAnnotations>
 >>    <eAnnotations
 >>    </eAnnotations>
 >>      </eAnnotations>
 >>      <eAnnotations
 >>      </eAnnotations>
 >>      </eAnnotations>
 >>      <eAnnotations
 >>      </eAnnotations>
 >> unique="false"
 >>      </eAnnotations>
 >>      <eAnnotations
 >>      </eAnnotations>
 >> unique="false"
 >>      <eAnnotations
 >>      </eAnnotations>
 >>  </eClassifiers>
 >> </ecore:EPackage>
 The Netherlands
| Re: Teneo/Hibernate Column Annotation Column [message #95797 is a reply to message #95781] | Mon, 03 September 2007 23:30  |  |
 Thanks for the info. Infact the hibernate schema updates happens only for
 new objects that gets added and for new/changed relationships. Hibernate FAQ
 itself says schema update tool comes with no warranties. Here is the link
 which gives more info on Hibernate SchemaUpdate Tool.
 http://www.hibernate.org/119.html#A9
 Once again thanks for all the help. My life would have been a real hell
 without without Teneo. Teneo really rocks!!
 Phaneesh
 news:fbhhe0$rr6$1@build.eclipse.org...
 > Hi Phaneesh
 > updates the schema. For example my experience is that new indexes are also
 > only added in a create mode. So it seems to be a hibernate 'feature'.
 > gr. Martin
 > Phaneesh wrote:
 >> Hi Martin,
 >> set to the target column. But, the problem now is the schema is not
 >> getting updated.
 >> is not getting updated in the database. I am using oracle 10 database. If
 >> I change the hibernate.hbm2ddl.auto to create and then run it on a new
 >> schema the column length is set to the desired value. May be there is a
 >> sync issue. Please tell me whether I have set any other option in teneo?
 >> Regards
 >> Phaneesh
 >>> Hi Phaneesh,
 >>> ecore file or xsd)?
 >>> gr. Martin
 >>> Phaneesh wrote:
 >>>> Hi Martin,
 >>>> source=teneo.jpa
 >>>> created
 >>>> target
 >>>> column.
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>>   * @generated
 >>>>  String getValue();
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>>   * @generated
 >>>>  String getValue();
 >>>>   </property>
 >>>> Regards
 >>>> Phaneesh
 >>>>> Hi Phaneesh,
 >>>>> annotation
 >>>>> link
 >>>>> noted above).
 >>>>> gr. Martin
 >>>>> Phaneesh wrote:
 >>>>>> Hi,
 >>>>>> is in
 >>>>>> code
 >>>>>> remains
 >>>>>> getter
 >>>>>> Key: length
 >>>>>> Value: 500
 >>>>>>   * <p>
 >>>>>>   * </p>
 >>>>>>   * @see
 >>>>>> length='500'"
 >>>>>>   * @generated
 >>>>>>  String getValue();
 >>>>>> 2. JPA annotation
 >>>>>>   * <p>
 >>>>>>   * </p>
 >>>>>>   * @see
 >>>>>> @Column(length=500)
 >>>>>>  String getValue();
 >>>>>> me in
 >>>>>> Regards
 >>>>>> Phaneesh
 >>>>> The Netherlands
 >>> The Netherlands
 >>> nsPrefix="column">
 >>>    </eAnnotations>
 >>>    <eAnnotations
 >>>    </eAnnotations>
 >>>      </eAnnotations>
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>>      </eAnnotations>
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>> unique="false"
 >>> scale="2")"/>
 >>>      </eAnnotations>
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>> unique="false"
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>>  </eClassifiers>
 >>> </ecore:EPackage>
 > The Netherlands
| Re: Teneo/Hibernate Column Annotation Column [message #609615 is a reply to message #95247] | Sun, 02 September 2007 06:01  |  |
 gr. Martin
 Phaneesh wrote:
 > Key: length
 > Value: 500
 >   * <p>
 >   * </p>
 >   * @see
 >   * @generated
 >  String getValue();
 > 2. JPA annotation
 >   * <p>
 >   * </p>
 >   * @see
 > @Column(length=500)
 >  String getValue();
 > Regards
 > Phaneesh
 The Netherlands
| Re: Teneo/Hibernate Column Annotation Column [message #609625 is a reply to message #95423] | Sun, 02 September 2007 23:34  |  |
 column.
 * <p>
 * </p>
 * @see
 * @generated
 String getValue();
 * <p>
 * </p>
 * @see
 * @generated
 String getValue();
 </property>
 Phaneesh
 > Hi Phaneesh,
 > noted above).
 > gr. Martin
 > Phaneesh wrote:
 >> Key: length
 >> Value: 500
 >>   * <p>
 >>   * </p>
 >>   * @see
 >>   * @generated
 >>  String getValue();
 >> 2. JPA annotation
 >>   * <p>
 >>   * </p>
 >>   * @see
 >> @Column(length=500)
 >>  String getValue();
 >> Regards
 >> Phaneesh
 > The Netherlands
| Re: Teneo/Hibernate Column Annotation Column [message #609627 is a reply to message #95576] | Mon, 03 September 2007 05:17  |  |
 Hi Phaneesh,
 ecore file or xsd)?
 gr. Martin
 Phaneesh wrote:
 > Hi Martin,
 > column.
 >   * <p>
 >   * </p>
 >   * @see
 >   * @generated
 >  String getValue();
 >   * <p>
 >   * </p>
 >   * @see
 >   * @generated
 >  String getValue();
 >   </property>
 > Regards
 > Phaneesh
 >> Hi Phaneesh,
 >> noted above).
 >> gr. Martin
 >> Phaneesh wrote:
 >>> Hi,
 >>> Key: length
 >>> Value: 500
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>>   * @generated
 >>>  String getValue();
 >>> 2. JPA annotation
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>> @Column(length=500)
 >>>  String getValue();
 >>> Regards
 >>> Phaneesh
 >> The Netherlands
 The Netherlands
 name="column.ecore"
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eAnnotations>
 </eClassifiers>
 </ecore:EPackage>
| Re: Teneo/Hibernate Column Annotation Column [message #609634 is a reply to message #95617] | Mon, 03 September 2007 10:46  |  |
 updated.
 Phaneesh
 > Hi Phaneesh,
 > ecore file or xsd)?
 > gr. Martin
 > Phaneesh wrote:
 >> Hi Martin,
 >> source=teneo.jpa
 >> created
 >> target
 >> column.
 >>   * <p>
 >>   * </p>
 >>   * @see
 >>   * @generated
 >>  String getValue();
 >>   * <p>
 >>   * </p>
 >>   * @see
 >>   * @generated
 >>  String getValue();
 >>   </property>
 >> Regards
 >> Phaneesh
 >>> Hi Phaneesh,
 >>> noted above).
 >>> gr. Martin
 >>> Phaneesh wrote:
 >>>> Hi,
 >>>> in
 >>>> remains
 >>>> Key: length
 >>>> Value: 500
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>>   * @generated
 >>>>  String getValue();
 >>>> 2. JPA annotation
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>> @Column(length=500)
 >>>>  String getValue();
 >>>> in
 >>>> Regards
 >>>> Phaneesh
 >>> The Netherlands
 > The Netherlands
 > nsPrefix="column">
 >    </eAnnotations>
 >    <eAnnotations
 >    </eAnnotations>
 >      </eAnnotations>
 >      <eAnnotations
 >      </eAnnotations>
 >      </eAnnotations>
 >      <eAnnotations
 >      </eAnnotations>
 > unique="false"
 >      </eAnnotations>
 >      <eAnnotations
 >      </eAnnotations>
 > unique="false"
 >      <eAnnotations
 >      </eAnnotations>
 >  </eClassifiers>
 > </ecore:EPackage>
| Re: Teneo/Hibernate Column Annotation Column [message #609636 is a reply to message #95747] | Mon, 03 September 2007 13:48  |  |
 gr. Martin
 Phaneesh wrote:
 > Hi Martin,
 > updated.
 > Regards
 > Phaneesh
 >> Hi Phaneesh,
 >> ecore file or xsd)?
 >> gr. Martin
 >> Phaneesh wrote:
 >>> Hi Martin,
 >>> source=teneo.jpa
 >>> created
 >>> target
 >>> column.
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>>   * @generated
 >>>  String getValue();
 >>>   * <p>
 >>>   * </p>
 >>>   * @see
 >>>   * @generated
 >>>  String getValue();
 >>>   </property>
 >>> Regards
 >>> Phaneesh
 >>>> Hi Phaneesh,
 >>>> noted above).
 >>>> gr. Martin
 >>>> Phaneesh wrote:
 >>>>> Hi,
 >>>>> in
 >>>>> remains
 >>>>> Key: length
 >>>>> Value: 500
 >>>>>   * <p>
 >>>>>   * </p>
 >>>>>   * @see
 >>>>>   * @generated
 >>>>>  String getValue();
 >>>>> 2. JPA annotation
 >>>>>   * <p>
 >>>>>   * </p>
 >>>>>   * @see
 >>>>> @Column(length=500)
 >>>>>  String getValue();
 >>>>> in
 >>>>> Regards
 >>>>> Phaneesh
 >>>> The Netherlands
 >> The Netherlands
 >> nsPrefix="column">
 >>    </eAnnotations>
 >>    <eAnnotations
 >>    </eAnnotations>
 >>      </eAnnotations>
 >>      <eAnnotations
 >>      </eAnnotations>
 >>      </eAnnotations>
 >>      <eAnnotations
 >>      </eAnnotations>
 >> unique="false"
 >>      </eAnnotations>
 >>      <eAnnotations
 >>      </eAnnotations>
 >> unique="false"
 >>      <eAnnotations
 >>      </eAnnotations>
 >>  </eClassifiers>
 >> </ecore:EPackage>
 The Netherlands
| Re: Teneo/Hibernate Column Annotation Column [message #609637 is a reply to message #95781] | Mon, 03 September 2007 23:30  |  |
 Phaneesh
 > Hi Phaneesh
 > gr. Martin
 > Phaneesh wrote:
 >> Hi Martin,
 >> getting updated.
 >> Regards
 >> Phaneesh
 >>> Hi Phaneesh,
 >>> ecore file or xsd)?
 >>> gr. Martin
 >>> Phaneesh wrote:
 >>>> Hi Martin,
 >>>> source=teneo.jpa
 >>>> created
 >>>> target
 >>>> column.
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>>   * @generated
 >>>>  String getValue();
 >>>>   * <p>
 >>>>   * </p>
 >>>>   * @see
 >>>>   * @generated
 >>>>  String getValue();
 >>>>   </property>
 >>>> Regards
 >>>> Phaneesh
 >>>>> Hi Phaneesh,
 >>>>> annotation
 >>>>> link
 >>>>> noted above).
 >>>>> gr. Martin
 >>>>> Phaneesh wrote:
 >>>>>> Hi,
 >>>>>> is in
 >>>>>> code
 >>>>>> remains
 >>>>>> getter
 >>>>>> Key: length
 >>>>>> Value: 500
 >>>>>>   * <p>
 >>>>>>   * </p>
 >>>>>>   * @see
 >>>>>> length='500'"
 >>>>>>   * @generated
 >>>>>>  String getValue();
 >>>>>> 2. JPA annotation
 >>>>>>   * <p>
 >>>>>>   * </p>
 >>>>>>   * @see
 >>>>>> @Column(length=500)
 >>>>>>  String getValue();
 >>>>>> me in
 >>>>>> Regards
 >>>>>> Phaneesh
 >>>>> The Netherlands
 >>> The Netherlands
 >>> nsPrefix="column">
 >>>    </eAnnotations>
 >>>    <eAnnotations
 >>>    </eAnnotations>
 >>>      </eAnnotations>
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>>      </eAnnotations>
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>> unique="false"
 >>> scale="2")"/>
 >>>      </eAnnotations>
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>> unique="false"
 >>>      <eAnnotations
 >>>      </eAnnotations>
 >>>  </eClassifiers>
 >>> </ecore:EPackage>
 > The Netherlands
 Current Time: Fri Oct 31 05:54:07 EDT 2025
 Powered by FUDForum . Page generated in 0.75577 seconds |
