Home » Archived » Visual Editor (VE) » VE & eclipse-3.1
VE & eclipse-3.1 [message #95170] Wed, 29 June 2005 20:52 Go to next message
Originally posted by: bendlin.telesurf.com.py
Are you planning to support eclipse-3.1 soon?
Kind Regards,
DAB
Re: VE & eclipse-3.1 [message #95184 is a reply to message #95170] Wed, 29 June 2005 20:55 Go to previous messageGo to next message
Originally posted by: myersj.nospam.gmail.com
> Kind Regards,
> DAB
Try downloading VE 1.1 M2 and its required plugins from
http://www.eclipse.org/vep/
- Jeff
Re: VE & eclipse-3.1 [message #95199 is a reply to message #95184] Wed, 29 June 2005 21:38 Go to previous messageGo to next message
>> Kind Regards,
>> DAB
> - Jeff
Ok, I'll try that, but the requirements section says that version will
only work with 3.1RC2
Requirements - PLEASE READ THIS SECTION FIRST
These are the prerequisites to install the Visual Editor. They must be
downloaded and installed before the Visual Editor can be installed. At
this point in time since these are all drivers that are in development
and are not release drivers, they cannot be mixed and matched. For VE to
work they must match.
Note:
* JRE must be version 1.4.2 or greater for BeanInfo of SWT to work
correctly.
* This build works with Eclipse 3.1RC2.
Eclipse build eclipse-SDK-3.1RC1: (build page) (download win32 zip)
EMF build I200506091102: (build page) (download zip)
GEF Build 3.1RC1: (build page) (download zip)
Re: VE & eclipse-3.1 [message #95214 is a reply to message #95199] Wed, 29 June 2005 23:17 Go to previous messageGo to next message
Originally posted by: devmike.netcabo.pt
I don't know if it's of interest to anyone, but I tried installing VE
1.1M2 on Eclipse 3.1 and got a NullPointerException error everytime I
tried opening a visual class. Is anyone interested in the log file?
Miguel Barrosa
>>> Kind Regards,
>>> DAB
>> - Jeff
> Note:
> correctly.
Re: VE & eclipse-3.1 [message #95230 is a reply to message #95214] Wed, 29 June 2005 23:44 Go to previous messageGo to next message
Yes. Please open a bug report in Bugzilla against VE/Java Core and
attach the log file.
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: VE & eclipse-3.1 [message #95305 is a reply to message #95199] Thu, 30 June 2005 10:07 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
You can try the I20050623 driver. It works with RC3, and it should be
working with 3.1 final. We should be having an integration driver that
is based upon 3.1 final by end of day today (Thurs). There won't be
another milestone because it is just a matter of weeks that 1.1 will be
out as a release.
Rich Kulp
Re: VE & eclipse-3.1 [message #95474 is a reply to message #95305] Thu, 30 June 2005 15:42 Go to previous messageGo to next message
> out as a release.
I've tried 1.1M2 and I20050623 - both were installed without any error
or waning but no "Visual Class" menu appeared :(
I'm using 3.1 platform release.
Re: VE & eclipse-3.1 [message #95501 is a reply to message #95474] Thu, 30 June 2005 16:07 Go to previous messageGo to next message
Did you run -clean, are there any errors in the .log, do you have the
correct levels of EMF and GEF to go with Eclipse SDK and VE?
>>out as a release.
Rich Kulp
Re: VE & eclipse-3.1 [message #95530 is a reply to message #95501] Thu, 30 June 2005 17:07 Go to previous messageGo to next message
This extensions i have:
GEF-3.1RC1
JDT-3.1
PyDev-0.8.0
VE-I20050623
I am very surprised but there is no log was created at all.
# cat /home/syncat/workspace/.metadata/.log
No such file or directory
> >>out as a release.
Re: VE & eclipse-3.1 [message #95544 is a reply to message #95501] Thu, 30 June 2005 17:27 Go to previous messageGo to next message
Yes i did it like this:
../eclipse -clean -vmargs -Xms128M -Xmx1024M
GEF-3.1RC1
JDT-3.1
PyDev-0.8.0
VE-I20050623
be
that
be
> >>out as a release.
error
Re: VE & eclipse-3.1 [message #95560 is a reply to message #95544] Thu, 30 June 2005 17:30 Go to previous messageGo to next message
Did you bring down Eclipse SDK or just Eclipse runtime? It needs to be
Eclipse SDK. The Eclipse runtime doesn't have enough. The reason I
question this is because you explicitly mentioned JDT. JDT comes with
Eclipse SDK and such shouldn't need to be explicitly mentioned. That you
mentioned it makes me think you got the Eclipse Runtime and the JDT
download. That won't work.
Also, you did not mention EMF. Did you bring down EMF?
> GEF-3.1RC1
> JDT-3.1
> PyDev-0.8.0
> VE-I20050623
> be
> that
> be
>>>>out as a release.
> error
Rich Kulp
Re: VE & eclipse-3.1 [message #95589 is a reply to message #95560] Fri, 01 July 2005 01:39 Go to previous messageGo to next message
Yes, I use eclipse 3.1 platform but not SDK. I'll try to install SDK and let you know is it working.
I guess VE has EMF build inside.
> > GEF-3.1RC1
> > JDT-3.1
> > PyDev-0.8.0
> > VE-I20050623
> > be
> > that
> > be
> >>>>out as a release.
> > error
Re: VE & eclipse-3.1 [message #95646 is a reply to message #95589] Fri, 01 July 2005 09:57 Go to previous messageGo to next message
No, EMF is a separate download from VE. The download page on VE lists
exactly what is required. It requires Eclipse SDK, EMF, and GEF.
Rich Kulp
Re: VE & eclipse-3.1 [message #95875 is a reply to message #95646] Sun, 03 July 2005 05:51 Go to previous message
David J. Orme wrote:
VE 1.1M2 on Eclipse 3.1 and got a NullPointerException error everytime I
> Best regards,
> Dave Orme
Hi David. Here goes the log file.
!SESSION 2005-07-03 02:53:45.765
eclipse.buildId=I20050627-1435
java.version=1.5.0_02
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=pt_PT
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.jem.proxy 2 0 2005-07-03 02:54:24.187
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.UnsatisfiedLinkError: no swt-win32-3138 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1517)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Widget.<clinit>(Widget.java:69)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:140)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:454)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:50 5)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:392)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:202)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:369)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:268)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:812)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:710)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:382)
org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:278)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1865)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!ENTRY org.eclipse.ve.java.core 4 0 2005-07-03 02:54:24.343
!MESSAGE Exception thrown.
!STACK 0
org.eclipse.jem.internal.proxy.swt.DisplayManager.syncExec(D isplayManager.java:526)
org.eclipse.jem.internal.proxy.swt.JavaStandardSWTBeanConsta nts.invokeSyncExec(JavaStandardSWTBeanConstants.java:139)
org.eclipse.ve.internal.swt.WidgetProxyAdapter.invokeSyncExe c(WidgetProxyAdapter.java:64)
org.eclipse.ve.internal.swt.ControlProxyAdapter.basicInitial izationStringAllocation(ControlProxyAdapter.java:84)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:816)
!ENTRY org.eclipse.jem.proxy 2 0 2005-07-03 02:54:24.468
!MESSAGE
+++ Warning +++: Sun Jul 03 02:54:24 BST 2005 Project (Gestao
Proteses Dentarias)-VM for Gestao Proteses Dentarias:err>
java.lang.NoClassDefFoundError
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
org.eclipse.ve.internal.swt.targetvm.Environment$1.run(Envir onment.java:32)
Re: VE & eclipse-3.1 [message #608112 is a reply to message #95170] Wed, 29 June 2005 20:55 Go to previous message
> Kind Regards,
> DAB
- Jeff
Re: VE & eclipse-3.1 [message #608113 is a reply to message #95184] Wed, 29 June 2005 21:38 Go to previous message
>> Kind Regards,
>> DAB
> - Jeff
Note:
correctly.
Re: VE & eclipse-3.1 [message #608114 is a reply to message #95199] Wed, 29 June 2005 23:17 Go to previous message
Miguel Barrosa
>>> Kind Regards,
>>> DAB
>> - Jeff
> Note:
> correctly.
Re: VE & eclipse-3.1 [message #608115 is a reply to message #95214] Wed, 29 June 2005 23:44 Go to previous message
Dave Orme
Re: VE & eclipse-3.1 [message #608120 is a reply to message #95199] Thu, 30 June 2005 10:07 Go to previous message
out as a release.
Rich Kulp
Re: VE & eclipse-3.1 [message #608131 is a reply to message #95305] Thu, 30 June 2005 15:42 Go to previous message
> out as a release.
Re: VE & eclipse-3.1 [message #608869 is a reply to message #95474] Thu, 30 June 2005 16:07 Go to previous message
>>out as a release.
Rich Kulp
Re: VE & eclipse-3.1 [message #608874 is a reply to message #95501] Thu, 30 June 2005 17:07 Go to previous message
GEF-3.1RC1
JDT-3.1
PyDev-0.8.0
VE-I20050623
> >>out as a release.
Re: VE & eclipse-3.1 [message #608876 is a reply to message #95501] Thu, 30 June 2005 17:27 Go to previous message
GEF-3.1RC1
JDT-3.1
PyDev-0.8.0
VE-I20050623
be
that
be
> >>out as a release.
error
Re: VE & eclipse-3.1 [message #608880 is a reply to message #95544] Thu, 30 June 2005 17:30 Go to previous message
> GEF-3.1RC1
> JDT-3.1
> PyDev-0.8.0
> VE-I20050623
> be
> that
> be
>>>>out as a release.
> error
Rich Kulp
Re: VE & eclipse-3.1 [message #608886 is a reply to message #95560] Fri, 01 July 2005 01:39 Go to previous message
> > GEF-3.1RC1
> > JDT-3.1
> > PyDev-0.8.0
> > VE-I20050623
> > be
> > that
> > be
> >>>>out as a release.
> > error
Re: VE & eclipse-3.1 [message #608903 is a reply to message #95589] Fri, 01 July 2005 09:57 Go to previous message
Rich Kulp
Re: VE & eclipse-3.1 [message #608933 is a reply to message #95646] Sun, 03 July 2005 05:51 Go to previous message
> Best regards,
> Dave Orme
!MESSAGE
!STACK 0
!STACK 0
!MESSAGE
Previous Topic:Installing VE for Eclipse 3.1 final?
Next Topic:How to retrieve the information displayed in "Java Beans"
Current Time: Sat Jul 26 16:01:29 EDT 2025
Powered by FUDForum. Page generated in 0.11007 seconds
