| IWAB0213E Error in starting server. [message #95142] |
Tue, 26 April 2005 13:19  |
Originally posted by: bill.nospam.ca
I have been trying to follow the "Bottom Up Web Service" Tutorial but keep
running into the following error during step 12.
Any ideas?
I am running on Solaris with WTP M3, Eclipse M5a and tomcat 4.1.31.
Bill
org.eclipse.core.runtime.CoreException: Server Tomcat v4.1 Server @
localhost failed to start.
org.eclipse.wst.server.core.internal.Server.synchronousStart (Server.java:1484)
org.eclipse.jst.ws.internal.consumption.command.common.Abstr actStartServer.startProject(AbstractStartServer.java:110)
org.eclipse.jst.ws.internal.consumption.command.common.Abstr actStartServer.StartServer(AbstractStartServer.java:81)
org.eclipse.jst.ws.internal.consumption.command.common.Start ProjectCommand.execute(StartProjectCommand.java:106)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveForwardToNextStop(CommandFragmentEngine.java:208)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.run(SimpleCommandEngineManager.java:206)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager.runForwardToNextStop(SimpleCommandEngineManager.java:1 75)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:69)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.performFinish(WizardPageManager.java:157)
org.eclipse.wst.command.env.ui.widgets.DynamicWizard.perform Finish(DynamicWizard.java:338)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:670)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:342)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:543)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1009)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2728)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2427)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:173)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:100 3)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:557)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:507)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:421)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
| Re: IWAB0213E Error in starting server. [message #95202 is a reply to message #95142] |
Tue, 26 April 2005 19:11  |
Hi Bill,
A good test to see whether the problem is in the Web service wizards or
if its just an environment bug, is to try to start the Tomcat server
manually. You can start that server in your workspace by pressing the
start button from the server view.
If this doesn't work, delete that server and try creating a new server
instance and do whatever it takes to get that to run outside first.
Then in the wizard, you can select the working server.
You may also want to check the JRE version Tomcat is running on?
-seng
Bill Simakis wrote:
> keep running into the following error during step 12.
> Any ideas?
> Bill
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
FUDForum. Page generated in 0.03649 seconds
