Home » Language IDEs » Java Development Tools (JDT) » Plug-in needs to load the class which source it's called on, got ClassNotFoundException
Plug-in needs to load the class which source it's called on, got ClassNotFoundException [message #94985] Fri, 12 September 2003 03:01 Go to next message
Originally posted by: dimichsdg.sbcglobal.net
I'll appreciate if anyone give me a clue on how to do the following:
I'm creating a plugin that hooks on extention of Java files
(ICompilationUnit class).
In runtime in Java project when a user selects an action the plugin wizard
is called that performs
a build of the project and tries to load a selected class to perform some
activity on it,
but doesn't seem to find it.
I got ClassNotFoundException.
The project folder of the runtime workbench with the test project as
follows:
C:\eclipse\eclipse-3.0M3\runtime-workspace\
TestOfPlugin\ <<< project folder, that contains source and compiled class
files
Account.java & Account.class
When I check on System.getProperty("java.class.path"), it gives me:
C:\eclipse\eclipse-3.0M3\startup.jar.
The project classpath (getResolvedClasspath) shows /TestOfPlugin folder.
The code that tries to load the compiled class is:
try
Class c = Class.forName("Account");
Constructor constr = c.getConstructor(new Class[]{});
Object o = constr.newInstance(null);
System.out.println("toString: "+o);
catch (Exception e2)
e2.printStackTrace();
Re: Plug-in needs to load the class which source it's called on, got ClassNotFoundException [message #95341 is a reply to message #94985] Fri, 12 September 2003 15:58 Go to previous messageGo to next message
I meant how to solve the problem with classpath.
"Dmytro Semenov" <dimichsdg@sbcglobal.net> wrote in message
news:bjrqvt$vmh$1@eclipse.org...
> activity on it,
> follows:
> files
> try
Re: Plug-in needs to load the class which source it's called on, got ClassNotFoundException [message #95878 is a reply to message #95341] Mon, 15 September 2003 13:21 Go to previous message
Originally posted by: richkulp.NO--SPAM.us.ibm.com
See:
http://eclipsewiki.swiki.net/114#augmentedClasspath2
Rich
Previous Topic:PostgreSQL JDBC Driver Not Found
Next Topic:ANT rmic task failing from Eclipse
Current Time: Sat Jul 26 14:08:00 EDT 2025
Powered by FUDForum. Page generated in 0.05307 seconds
