Can't install CDT correctly [message #94961] |
Fri, 20 February 2004 15:31  |
Originally posted by: Lauzon-Duranceau.Francis.ireq.ca
ViergeHi,
I installed CDT but when I try to create a new project, it never works,
anyone has any idea?
System:
QNX 6.2.1 (and 6.1)
Eclipse 2.1.1 (and 2.1)
corresponding Versions of full CDT
Everytime I try to start a "Managed Make C++ Project" within
Eclipse(CDT...), it does only half its job and stops with the following
message:
Project cannot be created
Reason:
Errors during build
When I check at the .log file I get this :
!ENTRY org.eclipse.core.resources 2 75 Feb 20, 2004 14:40:11.121
!MESSAGE Errors during build.
!SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 2 75 Feb 20, 2004
14:40:11.121
!MESSAGE java.lang.NullPointerException encountered while running
org.eclipse.cdt.managedbuilder.internal.core.GeneratedMakefi leBuilder.
!STACK 0
Stack trace:
java/lang/Throwable.<init>()V
java/lang/Throwable.<init>(Ljava/lang/String;)V
java/lang/NullPointerException.<init>(Ljava/lang/String;)V
org/eclipse/cdt/managedbuilder/internal/core/GeneratedMakefi leBuilder.build(
ILjava/util/Map;Lorg/eclipse/core/runtime/IProgressMonitor;) [Lorg/eclipse/co
re/resources/IProject;
org/eclipse/core/internal/events/BuildManager$2.run()V
org/eclipse/core/internal/runtime/InternalPlatform.run(Lorg/ eclipse/core/run
time/ISafeRunnable;)V
org/eclipse/core/runtime/Platform.run(Lorg/eclipse/core/runt ime/ISafeRunnabl
e;)V
org/eclipse/core/internal/events/BuildManager.basicBuild(ILo rg/eclipse/core/
resources/IncrementalProjectBuilder;Ljava/util/Map;Lorg/ecli pse/core/runtime
/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonitor;)V
org/eclipse/core/internal/events/BuildManager.basicBuild(Lor g/eclipse/core/r
esources/IProject;ILjava/lang/String;Ljava/util/Map;Lorg/ecl ipse/core/runtim
e/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonitor;)V
esources/IProject;I[Lorg/eclipse/core/resources/ICommand;Lor g/eclipse/core/r
untime/MultiStatus;Lorg/eclipse/core/runtime/IProgressMonito r;)V
org/eclipse/core/internal/events/BuildManager$1.run()V
and a lot of other lines after...........
I think it may be related to something about linking the libraries manually
in my PATH and LD_LIBRARY_PATH but I don't know which one,,,,
Thanks for any help.
Francis
Re: Can't install CDT correctly [message #95212 is a reply to message #94961] |
Tue, 24 February 2004 09:58   |
Hi Francis,
I was running into a lot of problems myself (not the same), but I ended up
switching to the beta 3.0 eclipse and a lot of the problems disappeared.
David
Francis wrote:
> ViergeHi,
> System:
> QNX 6.2.1 (and 6.1)
> message:
> Reason:
> Errors during build
> 14:40:11.121
> !STACK 0
> Stack trace:
> e;)V
> Francis
FUDForum. Page generated in 0.03745 seconds
