Home » Archived » Visual Editor (VE) » Launch mode run not supported for configuration type org.eclipse.jem.proxy.Local
Launch mode run not supported for configuration type org.eclipse.jem.proxy.Local [message #94929] Mon, 27 June 2005 07:52 Go to next message
does anyone know what's wrong with my VE installation.
Whenever i open a visual class loads of the following exeptions appear:
org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.core.runtime.CoreException: Launch mode run not supported for
configuration type org.eclipse.jem.proxy.LocalProxyLaunchConfigurationType
org.eclipse.debug.internal.core.LaunchConfigurationType.getD elegate(LaunchConfigurationType.java:221)
org.eclipse.debug.internal.core.LaunchConfiguration.getDeleg ate(LaunchConfiguration.java:360)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:514)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:150)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:432)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:299)
org.eclipse.jem.internal.proxy.core.ProxyLaunchSupport.start Implementation(ProxyLaunchSupport.java:231)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:157)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
I am using:
Eclipse 3.0.1
VE 1.0.2.1
EMF 2.0.1
GEF 3.0.1
TIA
Thomas Porcham
Re: Launch mode run not supported for configuration type org.eclipse.jem.proxy.Local [message #94989 is a reply to message #94929] Mon, 27 June 2005 11:25 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Did this all of sudden just start happening? If it did, what was the
last thing you did? If you installed new VE or something using unzip,
then make sure you start with -clean on the Eclipse command line once so
that it can re-process the plugin.xml's.
Rich Kulp
Re: Launch mode run not supported for configuration type org.eclipse.jem.proxy.Local [message #95004 is a reply to message #94989] Mon, 27 June 2005 12:05 Go to previous message
Many thanks!
The -clean option helped!
The last thing I did was the tutorial "Extending the Visual Editor
Tutorial: Enabling support for a custom widget"
Maybe that caused this behavior.
Thomas Porcham
Re: Launch mode run not supported for configuration type org.eclipse.jem.proxy.Local [message #608096 is a reply to message #94929] Mon, 27 June 2005 11:25 Go to previous message
Rich Kulp
Re: Launch mode run not supported for configuration type org.eclipse.jem.proxy.Local [message #608098 is a reply to message #94989] Mon, 27 June 2005 12:05 Go to previous message
Many thanks!
Thomas Porcham
Previous Topic:JComboBox an VE ???
Next Topic:is ve parsing deterministic?
Current Time: Mon Jul 14 14:21:38 EDT 2025
Powered by FUDForum. Page generated in 0.06247 seconds
