Home » Eclipse Projects » GEF » Image (GIFF/TIFF) Editor
Image (GIFF/TIFF) Editor [message #94927] Thu, 18 September 2003 19:22 Go to next message
My current project needs to load/display a scanned document (image) in an
editor, and support annotation of that document (i.e. lasso, marquie,
annotate, highlite, etc.).
Can GEF be used to load an image from a file, and then apply edits
(drawing/text/etc.) to that image? Preferably the edits would apply to a
layer above the image, rather than modifying the original bitmap/image.
Even better, does something like this already exist that I could leverage?
-Mitch
Re: Image (GIFF/TIFF) Editor [message #94957 is a reply to message #94927] Thu, 18 September 2003 23:24 Go to previous message
This does not exist. You could create such an application with GEF.
Painting into an SWT image might be slow if you want to do anything other
than just pure GC calls, such as drawing aliased lines. You might also end
up heavily customizing the undo mechanism, since you might use snapshots to
rollback paints.
"Mitch Christensen" <mitchellch@comcast.net> wrote in message
news:bkden6$j53$1@eclipse.org...
> -Mitch
Previous Topic:Create new command from within command?
Next Topic:Problem with triangle sizing.
Current Time: Sun Aug 31 07:44:24 EDT 2025
Powered by FUDForum. Page generated in 0.03112 seconds
