Home » Modeling » BPEL Designer » installing BPEL designer
installing BPEL designer [message #8570] Mon, 25 June 2007 15:06 Go to next message
Originally posted by: lario*NOSPAM*.inherit.com
I have followed the directions from http://www.eclipse.org/bpel/install.php.
I checked out and compiled :
a.. org.eclipse.bpel.common.model
b.. org.eclipse.bpel.common.ui
c.. org.eclipse.bpel.model
d.. org.eclipse.bpel.ui
e.. org.eclipse.bpel.runtimes
from :pserver:anonymous@dev.eclipse.org:/cvsroot/technology. I placed the
jars in the plugin directory. I have also loaded WTP (Web Tools Platform)
1.5.x .
When I attemped to open OASISSampleProcess.bpel from the examples, I get the
following error:
"Unable to create this part due to an internal error. Reason for the
failure: The editor class could not be instantiated. This usually indicates
that the editor's class name was mistyped in plug.xml."
I checked the .log file and here is the error:
!ENTRY org.eclipse.osgi 2 0 2007-06-25 13:39:01.953
!MESSAGE The activator org.eclipse.bpel.ui.BPELUIPlugin for bundle
org.eclipse.bpel.ui is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.bpel.ui.BPELUIPlugin for bundle org.eclipse.bpel.ui is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:787)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescriptor.java:231)
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:841)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:608)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:422)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:259)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2639)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2570)
org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2562)
org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2547)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2542)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2526)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2517)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:644)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:603)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:285)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:138)
org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:19 4)
org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:17 5)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:268)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:244)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:318)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:588)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:850)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:45)
org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:15 3)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1178)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3673)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3284)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2337)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2301)
org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 76)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:463)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:458)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:101)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:146)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:356)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:171)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown
Source)
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 476)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:416)
at org.eclipse.equinox.launcher.Main.run(Main.java:1141)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:434)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 72 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.bpel.ui.BPELUIPlugin
Source)
!ENTRY org.eclipse.ui 4 0 2007-06-25 13:39:01.968
!MESSAGE Unable to create editor ID org.eclipse.bpel.ui.bpeleditor: The
editor class could not be instantiated. This usually indicates that the
editor's class name was mistyped in plugin.xml.
!STACK 0
java.lang.ClassNotFoundException: org.eclipse.bpel.ui.BPELEditor
Source)
Re: installing BPEL designer [message #8626 is a reply to message #8570] Tue, 26 June 2007 14:28 Go to previous message
Rpbert,
We have just moved the tip to WTP 2.0 and the Europa release of Eclipse.
I will update the page soon, but generally, directions are the same but
the base install should be
GEF-ALL-3.3RC3.zip
dtp-sdk_1.5RC3.zip
eclipse-SDK-3.3RC4-win32.zip
emf-sdo-xsd-SDK-2.3.0RC3.zip
wtp-sdk-S-2.0RC3-200706140654.zip
Also the examples are not quite yet migrated to the new BPEL 2.0 namespaces.
-michal
> 1.5.x .
> following error:
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> at
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> ... 72 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
Previous Topic:Eclipse BPEL Designer Documentation
Next Topic:1
Current Time: Sun Aug 31 23:09:14 EDT 2025
Powered by FUDForum. Page generated in 0.03277 seconds
