Home » Archived » Memory Analyzer (MAT) » MAT not showing entire HEAP ?
MAT not showing entire HEAP ? [message #8563] Mon, 19 January 2009 16:13 Go to next message
I have this strange behaviour : when jmap creates a 1.7go heap dump from
my production server, MAT only shows :
Size: 349,7 MB Classes: 27k Objects: 6,6m Class Loader: 11,3k in
Overview/Details when open it up.
Is it so that the remaining 1.4 is free and available to allocate more
objets ?
I am running Probe into Tomcat (5.5.26). Probe shows approx. 80% of used
memory.
Can someone help me understand where my memory is going...
Thanks in advance
Anthony.
Re: MAT not showing entire HEAP ? [message #8581 is a reply to message #8563] Tue, 20 January 2009 07:11 Go to previous message
Hi Anthony,
when a heap dump is written, MAT removes objects which are not reachable
anymore. The reason is this: depending on the algorithm, the garbage
collector actually leaves some garbage behind. For example, some objects
are converted into pseudo byte arrays in order to avoid moving and
re-addressing objects.
However, this "waste" is usually only about 3 to 4 per cent of the heap.
You can print a class histogram of the removed objects following these
instructions: https://bugs.eclipse.org/bugs/show_bug.cgi?id=245410#c1
There could possible more reasons: sometimes the VM does not write a
complete heap dump. And, of course, it could also be a bug. And then we
would like to fix the problem. So if you run into many objects being
removed, it would be great to get my hands on the dump.
Let me know if you have further questions.
Kind regards,
Andreas.
Previous Topic:Finding (ascii) strings in byte[] data
Next Topic:Creating a query plugin with graphs
Current Time: Thu Nov 06 05:38:46 EST 2025
Powered by FUDForum. Page generated in 0.03872 seconds
