Home » Eclipse Projects » Equinox » Modal Popup/ToolTipText/Infopop?
Modal Popup/ToolTipText/Infopop? [message #94763] Tue, 14 August 2007 02:57
Originally posted by: david.j.fleming.jpmorgan.com
I have the need to display some metadata linked to each form on a
multi-form Eclipse RCP GUI - I have added toolTipText's on the form
headers to display this info, but in certain cases, the data spreads to
5-10 lines - given the toolTipText disappears after 5ish seconds, so this
is not a satisfactory solution. This data needs to persist for as long as
the user requires & it would also be preferrable to be able to copy the
info. to the clipboard.
Is it possible to implement a modal popup similar to those in the Eclipse
editor that you get when you hover over an object/method/etc. & can press
F2 to get a modal popup?
Thanks & Regards,
Dave
Previous Topic:LDAP Filter using Declarative Services
Next Topic:Example ant build - Content Provider not set for site?
Current Time: Thu Jun 05 00:50:14 EDT 2025
Powered by FUDForum. Page generated in 0.04006 seconds
