Home » Language IDEs » ServerTools (WTP) » JSP Include files
JSP Include files [message #94668] Sun, 24 April 2005 23:36 Go to next message
I've been seeing bunch of problems with include files. Anyone else having
problems?
One very annoying problem is that the editor doesn't know about variable
that are defined in an include file.
It looks like there is an open bug for this, but I'm not sure that it's the
same problem that I'm seeing.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=71223
Re: JSP Include files [message #94728 is a reply to message #94668] Mon, 25 April 2005 10:05 Go to previous messageGo to next message
Originally posted by: pavery.us.ibm.com
Hi Jason,
a couple of questions:
What is they syntax of the include you're using in your JSP (and the
path to the included JSP)?
Also, what type of project are you in?
Do you have a simple example to demonstrate this problem?
-phil
> problems?
Re: JSP Include files [message #94787 is a reply to message #94728] Mon, 25 April 2005 12:34 Go to previous messageGo to next message
<%@ include file="../inc/header.jsp" %>
I'm still using standard java projects since I don't see anyway to convert
an existing project/
Not right now, but I'll try to put something together later today.
Re: JSP Include files [message #94984 is a reply to message #94728] Tue, 26 April 2005 05:25 Go to previous messageGo to next message
Maybe I can give you some example. I am on 3.1, Linux MDK 10.1, Dynamic Web
Project.
I have a jsp-file portal.jsp with starts with
<%@ page import="java.sql.Connection" %>
<%@ page import="java.sql.ResultSet" %>
<%@ include file="/lib/jsp/config.jsp" %>
<%@ include file="/lib/jsp/format.jsp" %>
<%@ include file="/lib/jsp/util.jsp" %>
// void main()
HTML_CreateHeader("Intranetportal", out);
// Javascript-Bibliotheken SIS
HTML_LibJS(cLibJSPathSIS,"config.js", out);
First issue is, that alle the SQL-includes are marked as not needed, because
they are not needed in portal.jsp but in util.jsp, format.jsp and
config.jsp.
Next issue: the functions HTML_CreateHeader and HTML_LibJS, defined in
format.jsp, and constant cLibJSPathSIS, defined in config.jsp, are marked
red (not found).
Its not really a problem, because the jsp file works fine, its just annoying
to see everything marked yellow and red.
Benedikt
fragment from format.jsp:
void HTML_CreateHeader(String sTitle, javax.servlet.jsp.JspWriter out)
throws java.io.IOException {
out.println("<html>");
out.println("<head>");
out.println("<meta name=\"author\" content=\"Benedikt Wismans\">");
out.println("<title>"+sTitle+"</title>");
out.println("</head>");
Re: JSP Include files [message #95064 is a reply to message #94984] Mon, 25 April 2005 22:06 Go to previous messageGo to next message
Ah this example does look the same as:
I was just wondering if it was something else (I thought Jason has said
a "../path/to/file.jsp" wasn't working)
I agree that the squiggles are annoying, and there is actually loss
of function (eg. no content assist for classes defined in the included
files).
Hopefully we can address this issue soon (probably by using a
WebURIResolver in JSPTranslator).
-phil
> Project.
> // void main()
> config.jsp.
> red (not found).
> Benedikt
Re: JSP Include files [message #95278 is a reply to message #94787] Tue, 26 April 2005 23:41 Go to previous messageGo to next message
I've been trying to create a simple example that reproduces the errors I'm
seeing in my application, but so far I can't break the jsp editor.
I guess there is something extra weird in my application that is causing
problems.
Re: JSP Include files [message #95842 is a reply to message #95278] Wed, 27 April 2005 21:37 Go to previous messageGo to next message
> problems.
Thanks for trying to track it down Jason.
If you figure out what it is, definitely open a bug.
It's helpful since somtimes it's hard for us to think of these "special"
test cases (that users seem to find quite easily =)
-phil
Re: JSP Include files [message #96813 is a reply to message #95064] Sun, 01 May 2005 15:08 Go to previous messageGo to next message
Originally posted by: btabenkin.verizon.net
I have 2 questions:
1. Should the include file be called something.jsp? If you do this, the
app server bulk compiler might fail since some of the include files are
just fragments. We use "inc", is that ok
2. I posted a question earlier, but jut to reiterate, should I expect
edit of the include files to allow variable inspection and debug support?
> files).
> Thanks
> -phil
>> Dynamic Web
>> Project.
>> // void main()
>> because
>> config.jsp.
>> red (not found).
>> annoying
>> Benedikt
>> Wismans\">");
Re: JSP Include files [message #97627 is a reply to message #96813] Mon, 02 May 2005 23:10 Go to previous message
BT wrote:
> I have 2 questions:
>> said a "../path/to/file.jsp" wasn't working)
>> files).
>> Thanks
>> -phil
>>> Dynamic Web
>>> Project.
>>> // void main()
>>> because
>>> config.jsp.
>>> marked
>>> red (not found).
>>> annoying
>>> Benedikt
>>> Wismans\">");
Previous Topic:Re: JSP Include files
Next Topic:Using WTP for JSP debuging
Current Time: Sun Nov 09 08:31:36 EST 2025
Powered by FUDForum. Page generated in 0.05370 seconds
