Home » Modeling » GMF (Graphical Modeling Framework) » Using Context Menu/Popup Menu in gmftool model
Using Context Menu/Popup Menu in gmftool model [message #94649] Fri, 19 January 2007 18:33 Go to next message
Originally posted by: rbbnjmn.yahoo.com
I've added a Context Menu to my gmftool model; then referenced it
under context menu for the Node Mapping in the gmfmap model.
After regenerating the gmfgen model and generating all the diagram
code... I can't see that anything has changed running / editing the
diagram.
Also added a popmenu to my tooling model (gmftool).... don't see that
anything has changed, even in the plugin.xml.
I didn't find any documentation on these features and or how to use them.
I can of course add all these things manually; but I'm looking to use the
tools as much as possible. Probably I'm missing something.
Anyone know how to utilize these tool based features ?
Roy
Re: Using Context Menu/Popup Menu in gmftool model [message #95039 is a reply to message #94649] Mon, 22 January 2007 08:39 Go to previous messageGo to next message
Hello rbbnjmn,
GMF is not able to generate popup menu nuw. This is just a "place-holder"
in GMF tooling model for future.
Alex Shatalin
Re: Using Context Menu/Popup Menu in gmftool model [message #1504694 is a reply to message #95039] Tue, 09 December 2014 08:25 Go to previous message
Is this still true?
Previous Topic:Create multiple nodes from a single palette entry
Next Topic:XSD for diagram file
Current Time: Sun Aug 31 01:41:38 EDT 2025
Powered by FUDForum. Page generated in 0.04064 seconds
