Dynamic markers in chart, based on parameter [message #94594] |
Mon, 28 November 2005 06:31  |
Originally posted by: maspeli.deloitte.co.uk
I have a scatter chart which uses a data set based that's parameterised with
a date. I'd like to show this date as a marker on the chart (the chart will
include this date and a number of months before and after the given date).
However, the Markers part of the chart properties only permits the use of
static values.
Is it possible to set the marker dynamically with a script? If so, what
would that look like?
Martin
Re: Dynamic markers in chart, based on parameter [message #95368 is a reply to message #94594] |
Tue, 29 November 2005 14:29  |
Originally posted by: none.none.com
Hi Martin,
Yes, you can use a script to modify the chart design. Please look at the
script specification for details.
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS18
David
"Martin Aspeli" <maspeli@deloitte.co.uk> wrote in message
news:dmepqd$d7r$1@news.eclipse.org...
> with
> will
> static values.
> Martin
FUDForum. Page generated in 0.09418 seconds
