Home » Modeling » GMF (Graphical Modeling Framework) » Deletion not working
| Deletion not working [message #94558] |
Fri, 19 January 2007 10:08  |
Originally posted by: kalin.nakov.gmail.com
Once I attach an element on the border of a node (side-affixed), I
cannot delete it or its parent. Actually it is deleted, but the diagram
is not refreshed - the select handles disappear and the deleted nodes
remain as dead in the canvas, I have to reopen it to see the changes. Is
it a known bug with a workaround, or if not where should I fix that in
the source?
Kalin
| Re: Deletion not working [message #94878 is a reply to message #94708] |
Mon, 22 January 2007 02:18   |
I am using GMF2.0M3. So this bug must be older. Unfortunately I'm not
that much inside the GMF framework and I still have no clue how can I
create a workaround for this in the source code. I really need to
workaround this :-)
Kalin
Sandip Sahoo wrote:
> If u r using GMF2.0M4, then I also faced the same. I think it is a bug.
> Regards
> "Kalin Nakov" <kalin.nakov@gmail.com> wrote in message
> news:eoqmt8$u50$1@utils.eclipse.org...
>> Hello,
>> the source?
>> Thanks,
>> Kalin
| Re: Deletion not working [message #95145 is a reply to message #94878] |
Mon, 22 January 2007 09:10   |
Hello Kalin,
We are actually using side-affixed nodes for Activity (Pins) and Class Diagram
(Ports) for MDT UML2Tools project.
With sources generated for GMF 2.0 M4 we do not have any problems with deletion
of these elements.
We also did not see anything similar with older GMF versions, so most probably
the issue is in your definition models.
Please feel free to send me representative parts of your GMF resources to
check what may be the problem.
Michael
> workaround this :-)
> Kalin
> Sandip Sahoo wrote:
>> bug.
>> Regards
>>> Hello,
>>> diagram is not refreshed - the select handles disappear and the
>>> deleted nodes remain as dead in the canvas, I have to reopen it to
>>> see the changes. Is it a known bug with a workaround, or if not
>>> where should I fix that in the source?
>>> Thanks,
>>> Kalin
| Re: Deletion not working [message #123827 is a reply to message #95145] |
Thu, 03 May 2007 08:16  |
Originally posted by: swanbrook66.gmail.com
Hi ,
I was wondering if there was any solution found for this issue as i am
now encountering the exact same issue?
Thanks a lot.
"Michael Golubev" <michael.golubev@borland.com> wrote in message
news:80ef434010e68c90c4e889f57a7@news.eclipse.org...
> Hello Kalin,
> Diagram (Ports) for MDT UML2Tools project. With sources generated for GMF
> 2.0 M4 we do not have any problems with deletion of these elements. We
> probably the issue is in your definition models.
> Regards, Michael
>> workaround this :-)
>> Thanks,
>> Kalin
>> Sandip Sahoo wrote:
>>> Hi,
>>> bug.
>>> Regards
>>>> Hello,
>>>> Thanks,
>>>> Kalin
Current Time: Tue Nov 04 21:41:15 EST 2025
Powered by FUDForum. Page generated in 1.06178 seconds
