Home » Newcomers » Newcomers » Eclipse Remote Debugging Source Not Found
Eclipse Remote Debugging Source Not Found [message #94307] Fri, 12 August 2005 08:36 Go to next message
I am using Eclipses remote in remote debug mode. I can attach to my
application. The problem is that the debugger automatically stops in
areas where it cannot find source code for areas I do not even care about.
For example, I get a Class File Editor window that pops up as an editor
and says "Source not found, The jar file rt.jar has no source attachment."
How do I change the debugging settings so it does not stop here? It also
stops on lines that are yellow in the IDE because they are not 100%
compatible with Java 1.5 generics. I just want to get to my source, but
it takes many F8's to get there.
Chris
Re: Eclipse Remote Debugging Source Not Found [message #94352 is a reply to message #94307] Fri, 12 August 2005 10:23 Go to previous messageGo to next message
> about. For example, I get a Class File Editor window that pops up as an
> editor and says "Source not found, The jar file rt.jar has no source
> attachment."
> also stops on lines that are yellow in the IDE because they are not 100%
> Chris
The Eclipse Debugger ships with some Suspend Execution preferences
enabled by default. You can disable them in Preferences/Java/Debug. Many
people find that disabling the "Suspend execution on uncaugth
exceptions" is useful when debugging their applications.
Also, in the Debug View, the suspended thread should tell you why it
suspended. This may give you more insight into what is happening and
help you find the preference you need to change.
HTH
Kevin
Re: Eclipse Remote Debugging Source Not Found [message #94423 is a reply to message #94352] Fri, 12 August 2005 13:13 Go to previous messageGo to next message
Thanks Kevin for showing me that. I cheked off the options :
- Suspend extecution on uncaught exceptions
- Suspend exectution on compilation errors.
The app is still stopping though. Here is one thread
Thread[main] (suspended (execption ArrayIndexOutofBoundsException))
SignatureParser.current() line: not avaialable
plus other lines in the stack.
Then it it puts up the window: Class File Editor source Not Found.
The app does not crash though. Any other ideas?
Chris
Re: Eclipse Remote Debugging Source Not Found [message #94453 is a reply to message #94423] Fri, 12 August 2005 13:33 Go to previous messageGo to next message
I would guess that you have an exception breakpoint either for
ArrayIndexOutofBounds or for one of its superclasses?
HTH
Darins
"Chris" <chris@transformsw.com> wrote in message
news:f8fd1fbfde8de0b826eb8a18182ce898$1@www.eclipse.org...
> Chris
Re: Eclipse Remote Debugging Source Not Found [message #94468 is a reply to message #94453] Fri, 12 August 2005 13:33 Go to previous message
Check the breakpoints view for these breakpoints
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:ddimdr$ne2$1@news.eclipse.org...
> HTH
> Darins
> > Thanks,
> > Chris
Previous Topic:Browser window timeout while debugging
Next Topic:Removing Plugins
Current Time: Tue Dec 02 13:22:11 EST 2025
Powered by FUDForum. Page generated in 0.09665 seconds
